Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Red lines, green lines, now static!
The tv is only 3 years old. 2 months ago noticed red horizontal lines rolling up the screen. just took out the lamp to wipe it down and now instead of red lines, we have green lines and tons of static! Any help would be appreciated!
    Genius:
  • 1,153 Answers
Uneven colors with multicolored lines in the center of the picture and/or flashing, C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB (part # 930B921002)
Posted on Nov 29, 2007
Horizontal Green Lines On Screen. No Picture Visible. Problem is intermitent.
Are you certain of the connection? Sometimes the connector becomes loose or otherwise loses integrity. Maybe it's the cable (HDMI, right?)--or both the TV's connector and that. They may become worn.
Be careful with your LCD screen--they are more delicate than most people realize.....
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
Sanyo flat screen tv about 2 yrs old has thin colored horizontal lines down the right side
Nothing you can do about that...get used to it or change the TV.
It's a defect in the panel that can't be reliably fixed.
Feb 15, 2013 | Sanyo DP46848 LCD TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Horizontal lines on screen after STR6301 replcement
hi just by using a 3-2 prong converter which is found at a hardware store can take away ur problem. It takes the plug into the wall from a 3 prong plug to a 2 prong plug and is supposed to work. try it and let me know if it works....
May 24, 2009 | Sony Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Green lines at top
well i think your husband is right. it might be three years old, but the sligtest damage can kill it. so what you need to do is start saving up for a new tv. sorry for waht happened. maybe somebody hit the screen?
Sep 01, 2007 | RCA 27R410T 27" TV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Green Lines Horizontally
yeppers its a g2 control on the flyback thats gone or drifted out of alighnment or the flyback its self.Try turning the g2 control dowm till those lines fade. If they wont go away then you need someone to check the Picture tube or its componets driving the crt.
Mar 26, 2006 | GE 31GT740 31" TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
368 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
