Question about HP DeskJet F380 All-In-One Printer
Green overcast I have a HP All In One 7170. I just put new ink in and it has a green overcast. (It was doing this before the new ink too)
I have lost my cd for the printer so just i want download prohram for my printer
Posted on Dec 20, 2007
Hp 7960 prints in all green
it sounds like another color could be low or empty
Nov 20, 2012 | HP PhotoSmart 7960 InkJet Printer
I just installed my new HP officejet H470 printer. The light is blinking green and it says that the carriage is stalled... what do I do?
make sure plastic or tape is off the ink cardlidges that came with computer theres 2 of them and they peel off the fron of ink cardlidge then put them back in and then restart computer.
Feb 17, 2011 | HP Officejet H470 InkJet Printer
New HP 56 cartridge prints green
hello, are you sure its green, since this is a black in cart, only thing i can think of is machine not printing black , and the color ink cartridge is contaminated, this would be due to the docking area for the cartridge, on the left side of machine, there are 2 black rubber cups that the ink cartridges move over to seal. sometimes these cups have residual ink, which will contaminate the new inks. clean these black cups, and replace inks
Sep 24, 2010 | HP PSC 1210 All-In-One InkJet Printer
Error 2200 on 7170 lexmark
The error indicates that the scanner has stalled or jammed. Here's an article on 2200 Error on the Lexmark X7100 Series All-In-One. Just click on this link: http://bit.ly/aBUoJK. Just follow the troubleshooting steps on the page. If all else fails, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks.
Jul 27, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Says cartridge cannot be used after initialization but brand new HP 363 cartridge sent directly by HP to me. This happens ever time I put a new cartridge in when prompted by printer to do so. Do I put new...
The following are common issues.
The following ink cartridges cannot be used after device initialization and must be replaced
Cause The wrong ink cartridge(s) are installed.
Solution The indicated ink cartridge(s) cannot be used after the device has undergone first time setup. Replace the ink cartridge(s) with the appropriate ink cartridges for the HP All-in-One. To find out the reorder number for all the ink cartridges that the HP All-in-One supports, see the printed documentation that came with the HP All-in-One.
If you are using compatible cartridges make sure they are reset for use.
Ink cartridge problem
Cause The indicated ink cartridge(s) are missing or are damaged.
Solution Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-One, the ink cartridge contacts might need to be cleaned. If there are no ink cartridges missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge.
Sep 21, 2009 | HP Photosmart 3310 Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
D1360 black ink didn't print and green light keep flashing
just unplug the power cable and usb cable from the back side of the printer and let it be for an hour it will help
Apr 15, 2008 | HP Deskjet D2360 InkJet Printer
HP 57 refill problem
You are doing nothing wrong. The nozzles are clogged. Try taking a clean syringe and put your finger on one of the magenta (red) refill holes. Fill the syringe with air. Put it on the second magenta refill hole and blow the air inside. That should force out the ink that has dried and that is not letting the new ink come out. You might have to do that several times. Sometimes, it can help.
If that doesn't work, go to a refill shop, they should be able to clean the print nozzles on your cartridge, no need to buy new ones.
Feb 12, 2008 | HP Easy Refill Kit for (HP) Black Inkjet...
Green print
Try cleaning your ink nozzles or ink jets. It sounds like you have a plugged nozzle or two. Your printer program should have maintenance options that allow you to test for plugged nozzles and clean them.
In control panel, open the printing/fax icon, right click on your printers icon, left click properties, then on the bottom of the page the panel that opens you will see a button that says printing preferences, and that should open your print program.
This will work for all printers, not just hp.
Nov 26, 2007 | HP DeskJet F380 All-In-One Printer
Black and white has colour cast
pls first you take out printer test page from the printer without connecting to the computer if is correct pls change your usb cable and see.
Oct 20, 2007 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
