Question about Acer Aspire 5100 Notebook
Making address labels and envelopes
Does this vista program have a template for making address labels and envelopes?
  • 205 Answers
Vista is the operating system. I am not using Vista, but I can pretty much promise you there's nothing built in to create labels and envelopes.
Go to and take a look at their free software to create address labels using their products. I'm not sure if you can print directly on envelopes with their software, but if you have Microsoft Word on your computer it will do that for you.
Good luck.
Posted on Nov 27, 2007
How to print envelop on HP 3390
you would be better using sticker sheets.
see for an example
your local office supply shop would have something similar
Some labels have downloadable templates to make it easy to line up the addresses to the laser label sheets
Trying to print on the envelope could cause jams inside the printer
Aug 13, 2016 | HP LaserJet 3390 Printer
I cannot find a template using Microsoft Word - Envelopes & labels for Avery label #6873.
Try this:
  • On the tools menu, point to letters and mailings, and then click on mail merge
  • Under select document type, click envelopes the active document becomes the main document
  • Click Next: Starting document.
Aug 06, 2008 | Office Equipment & Supplies
How to address envelopes with the hpdeskjet printer
Use the downloadable MS Word template for the size of envelope you want to use.
Jul 28, 2016 | HP DeskJet 3520 InkJet Printer
I'm having trouble addressing an large envelope the printer wants to print from the upper photograph tray and not accept the envelope from the lower tray. I have the MX922 printer.
The upper tray on my 6120 has adjustable guides on either side of the document and can be set from 2" to 8.75" wide. It is not intended just for photos! I use it for ALL envelopes that will fit. I use the MS WORD "Mailings", "Envelopes", "Options", "Envelope Size" menu to tell the printer what size the envelope will be (any size not listed in the standard list can be customized from the CUSTOM option at the bottom of the envelope list). Your word processor should have something similar. Running from the tray should be a straighter run and will actually place less distortion stress on the envelope.
Use a mailing label for anything larger than 8.75". You can download a program from Avery (and probably other label manufacturers) that really makes labels simple to produce. Labels should also be run from the rear tray if possible so they won't wrap around your rollers.
Happy Printing.
Feb 10, 2015 | Canon Pixma MX922
When I try to print on a 6x6 envelope on my hp envy 110 printer it tells me it is the wrong size paper. No where is there a setting for a 6x6
Print labels and envelopes
With the HP ENVY 110 series, you can print on a single envelope, a group of envelopes, or label sheets
designed for inkjet printers.
To print a group of addresses on labels or envelopes
1. Print a test page on plain paper first.
2. Place the test page on top of the label sheet or envelope, and hold both up to the light. Check the spacing for
each block of text. Make adjustments as needed.
3. Load the labels or envelopes into the paper tray.
CAUTION: Do not use envelopes with clasps or windows. They can get stuck in the rollers and cause
paper jams.
4. Slide paper-width guides inward against the stack of labels or envelopes until the guides stop.
5. Select the appropriate options.
• On -Paper/Quality- tab select a Plain paper type.
• Click the [Advanced] button, and select the appropriate envelope size from the Paper Size drop down
6. Click [OK], and then click [Print] or [OK] in the Print dialog box.
If you print from within a program that DOES have that listed (like M$ Word,) then you don't need the limited printer driver to specify the paper size.
Sep 08, 2012 | HP ENVY 110 Wireless e-All-in-One Inkjet...
How do you print an address to an envelope? And can you only print #10 envelopes?
No, you can print on any envelope size. As far as addresses are concerned, you need to setup a template for the envelope size in your program. What program do you have for this function, do you have Microsoft Word or come other word processor like that?
Jul 11, 2011 | Canon Pixma MG8120 InkJet Printer
How do I set up my HP 3050 to print Avery labels 5160?
You need to download the templates they have online and edit them in Microsoft Word. Here is a link to the template:
Click the blue download template button and follow the instructions.
Mar 31, 2011 | Office Equipment & Supplies
Which labels for 6310 HP pinter?windows viista progar? 8160labels do not fit 6310 priinter
Vista wouldn't be your problem as your Operating System is unimportant in choosing labels but the program you use to print your labels is very important.
If you Use Microsoft Word, for example, you will need to choose the template for your labels. That number is on the box of labels.
In Word (for Instance) you can do the following:
<File>, <New>, <Templates> (templates are on Left side).
Choose your Type of Label and the Label number from there.
Otherwise, some label companies offer free programs, specifically for printing their labels.
AVERY labels has a free program for printing their label numbers and the Program: AVERY Wizard For microsoft Word is free.
I hope this helps as you do not say which program you use to print Labels and you also do not say which label numbers and/or label type you wish to print.
Thank You For Choosing FixYa~!
Mar 24, 2011 | HP Officejet 6310 All-In-One InkJet...
I have a Kodak ESP 5200 series printer. When I try to print Avery 8160 address labels the sheet comes out not printed.
You can try and download the label again from below link--
Avery 8160 label download
Click the "Download Template" button. Enter your info and click "Submit". Follow the prompts to download the file. After you download your Avery template, be sure to remember where you saved the file on your computer and the file name. Open Microsoft® Word or an Adobe® program for your template and select File > Open to navigate to the drive and folder to open your template. Use the program's formatting and printing features to edit and save your template. For Microsoft® Word users - If the template looks like a blank page, select Table > Show Gridlines to view the template layout.
Hope this helps... Please post back if you need more information.
Dec 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to print envelopes?
use the hp software ..and use the envelopes templates in the setup of the page ..or ...just open Microsoft office word ..and select the mailings and in the left side will be the envelopes template ..(office 2007)
Jun 03, 2010 | HP DeskJet 940c InkJet Printer
Acer Aspire 5100 Notebook Logo
118 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
