Question about Universal Televison & Video
I don't have a enter button on my Jumbo universal remote can you tell me what to use to enter the code another way please.
The 11 button is where the enter button is supposed to be. It has no brand it just says Jumbo universal remote
    Sergeant:
  • 313 Answers
Press OK button....
Posted on May 14, 2019
Testimonial: "Where is it?"
  • 3 more comments
  • The fun with Christian Fun time
    Can you tell me where it is on the remote? This is the picture of it.
    And those too buttons that are missing are the mute and use code
  • Akbar Mughal
    Akbar Mughal May 15, 2019
    This is remote.. in your remote there are symbol icons instead of OK or enter...please c it and match yourself.
    Oh can you tell me where it is on my remote?
  • Akbar Mughal
    Akbar Mughal May 16, 2019
    in your remote there is no written only icons.u try your self...i already provide the picture match it with your remote.There is enter batten match it with your.....
SOURCE:
  • 788 Answers
SOURCE: codes for jumbo universal remote
Codes for jumbo universal remote
Sorry to here about your emerson remote problems.
The best thing to do is go to emerson.com and search for your device by number.
You will be able to find and print all the codes you need for whatever devices.
Hope this information has been of some help.
Please rate your technician, as they take the time to answer your questions. !!
Even if you disagree, it shows us that you have taken the time to answer.
Thanks,
John Ray
john@johnrraycomputer.com
Posted on Jun 29, 2009
superminer
  • 26 Answers
SOURCE: Jumbo Universal Remote Control
DIRECTV all models 00001, 00002
also use 200-217 from the jumbo hand book good luck
please rate
Posted on Jan 13, 2008
SOURCE: lost codes for jumbo universal remote
press code search when it lights up press devise u want till light stays red then keep pressing power button slowley till it turns off the hold down enter for a sec and its set.
Posted on Apr 09, 2009
pidatoo
  • 118 Answers
SOURCE: need programming codes for Innovage Jumbo Remote
here is your manual. good luck.
http://www.remotecodelist.com/remotes/innovage/Jumbo_Universal_Remote.pdf
Posted on Jul 25, 2009
SOURCE: Universal Remote
I downloaded the tv's manual, mine is a model:1350, but it says at the bottom of the manual it is from Memorex, so I found the codes in my remote(a OneforAll brand code 0463) and it worked. So if you haven't solved your issue, do a memorex code. Now that I look at the date you probably have. Oh well.
Posted on Oct 08, 2008
How do i program the innovage jumbo universal remote
Jumbo universal remotes are essentially the same regardless of the name at the top. If you have a device you want to control, start by turning on that device. Press and hold CODE SEARCH until the red indicator stays on, then release the CODE SEARCH button. Press and quickly release the device button, e.g, TV. Point the remote directly at the device. Press the power button (in the upper right corner) repeatedly until the device responds, e.g., changes channel. Press ENTER and release to install the code. If no result, your Innovage jumbo remote may not have a suitable code available.
Oct 23, 2014 | Innovage Jumbo Universal Remote Control
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
Looking for a jumbo remote that will operate a new 26 inch Vizio Montior. The old one don't work. Is there a new version?
A remote is not designed to control and Moitor. They only run by the video/sound output from the pc. So I am taking it for granted that you meant TV instead of Monitor.
A. Before buying a new remote try replacing the batteries first.
B. I found the Innovage Jumbo Remote Control manual and it has no code for the Vizio TV, you will need to utilize the remote's "Code Search" option.
C. Instructions
1. Turn on the Vizio TV.
2. Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
3. Press the "TV" button at the top of the Jumbo Universal Remote.
4. Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. This will likely take several minutes due to the amount of available codes.
5. Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6. Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Good luck.
Jun 03, 2011 | Innovage Jumbo Remote Control
Innovage Jumbo Universal Remote and Comcast Cable
I do not see Comcast cable codes in the manual, so I recommend using the auto-search function for both CABLE and SAT to find one that works for you.
To have the remote try each CABLE or SAT code it knows one at a time, follow these steps:
  1. Turn on your cable box.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the CABLE or SAT button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the cable box turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the cable box turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 11, 2009 | Innovage Jumbo Remote Control
Do you have innovage remote codes for Vizio VO320E
I don't see Vizio TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 10, 2009 | Innovage Jumbo Remote Control
Liteon LVW5002 code for Jumbo uni mastercontroller
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 11, 2009 | Universal Remote Control MasterControl...
Innovage jumbo universal remote manual
to all of you guys who need the manual , please check this URL
http://www.vat19.com/dvds/jumbo-universal-remote-manual.pdf
if you all cannot download the manual, send me your emails so i can give email you a copy..
kamikaze_naderei@yahoo.com
Jan 13, 2008 | Big Button TV Universal Remote
Sharper Image Jumbo Universal Remote
i just pirchased a Sharper Image Jumbo universal Remote but i can't find a code for the Pioneer DVR 541H is DVD recorder. Does anyone have this code or  a suggestion?
Jan 10, 2008 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Universal Televison & Video Experts
JOHN TOPLISS
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
