Question about Homelite Garden
Correct fuel mixture for homelite xl per litre petrol
SOURCE:
  • 17 Answers
SOURCE: Fuel mixture on Homelite Chainsaw
Old 330 should be 25 to 1 (200ml to 5lt ulp)
some newer OPE oils like stihl 2st are 50 to 1 ,but use around 150ml to 5lt on old saws
Posted on Jan 08, 2009
slohry
  • 87 Answers
SOURCE: need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
Posted on Apr 12, 2009
  • 8 Answers
SOURCE: What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Posted on Jun 02, 2009
  • 3 Answers
SOURCE: homelite whipper snipper is hard to start and its
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Posted on Sep 15, 2009
Testimonial: "Thanks, will try it!!!"
SOURCE: Homelite CSP 3314 Chainsaw
starts no prob will not rev , just stalls when you try
Posted on Feb 14, 2010
Fuel ratio for homelite ut104444
The recommended 50-to-1 fuel mixture includes 2.6 ounces of a high-quality, two-cycle oil with added fuel stabilizers and 1 gallon of unleaded 87-octane gas. Homelite recommends using their brand of oils, specifically designed to work in any model with a 50-to-1 fuel ratio.
Homelite XL Textron Fuel Ratio ' Home Guides ' SF Gate
homeguides.sfgate.com/homelite-xl-textron-fuel-ratio-89880.html
May 13, 2018 | Homelite Garden
How many caps of two stroke oil to a 6 litres of petrol
Hi chainsaw mixture is 40 mls.of oil per 1 litre of fuel unleaded. Cheers
Jul 18, 2016 | Garden
Correct fuel mixture for homelite xl cahinsaw UT10695b
50:1 unleaded fuel,1 gal gas to 2.6 ounces of 2 stroke oil mix
Jul 17, 2016 | Homelite Garden
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
Sep 09, 2014 | Homelite Garden
CHAIN SAW HOMELITE FUEL
You should run your saw at 25:1
More tips and advice on different makes and model chainsaws here
Sep 15, 2012 | Homelite Garden
What is the fuel mixture?
hi there
pfrolander
the ratio of oil to petrol you should use is 50:1 ( that is 20 mils of hi quality 2 stroke oil per 1.0 litre of petrol you mix ) using hi quality sthil / husqvarna 2 stroke oil
1000 divided by 50 = 20 mils of oil per 1.0 litre of petrol
NOTE if you do not have any hi quality 2 stroke but some from your local garage ( that you may use in say a scooter for example use 40 mils of oil per litre it is richer
this will do the job
cheers hope it helps
May 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
I inherited a Rancher 50 20" chainsaw from my uncle only noone know the oil gas mixture.
using good quality 2 stroke oil use ratio 50:1
that is 20 mils of oil per 1 litre of petrol that you mix
put oil in can 1st then add petrol and give good shake
so if mixing 5 litres pour in 100 mils of 2 stroke oil and add 5 litres of fuel only
Aug 07, 2010 | Husqvarna Garden
WHAT IS THE FUEL/OIL MIXTURE FOR A POULAN PREDITOR 2150 CHAINSAW?
if using a good quality 2 stroke oil brand
mix it @ ratio 50:1 that is 100 mils of oil per 5 litres of petrol
or on a 1 litre basis it would be 20 mils of oil per litre
but !!!! if you are using generic 2 stroke oil from a garage
run it on 25:1 mix that is 40 mils of oil per litre of petrol
be sure to put required qty of in clean container 1st then add petrol qty to the can and give good shake , then fill your saw
paul
Jul 31, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel oil mixture for 1986 mercury 115
I own a small Mercury outboard so I did alittle reading in the manual and the ratio for your 86' 115 HP is 50-1. Hope it helps. Coach Theune
Oct 25, 2009 | Boating
Garden Logo
Top Homelite Garden Experts
roeb
Jay Finke
Jay Finke
Randy Schumann
Randy Schumann
Are you a Homelite Garden Expert? Answer questions, earn points and help others
