Question about ATI RADEON 9250, (256 MB) PCI Graphic Card
My computer won't come up any more
I was having problems with my video shaking then wthe last time i got it to come up the desktop was all messed up. Now it starts to come up it makes it to the windows splash screen then the monitor says no signal and the power light stays on but the hard drive light has no activity.
  • Pete Cook Nov 27, 2007
    My card only has 128 MB of memory in stead of 256
  • 24 Answers
I think you may be having problems with the video card...if it's still under warranty, I suggest an RMA from wherever you bought it.
Posted on Nov 28, 2007
  • Zoilo McCrocklin
    Zoilo McCrocklin Mar 15, 2008
    After reviewing your problem further, I say that you do have a problem with your video card. I have the same video card, manufactured by Crucial and this card works well for me. I suggest getting a warranty replacement if your card is still under warranty.
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
Lenovo z570 screen shaking problem
Hook a spare monitor to the video output usually on the back, if okay! the problem is in the LCD display, if symptoms are the same, you may have a virus, update definitions and run a deep or full scan of your system, if nothing shows, try a system restore and bring the computer back to an earlier time before this happened, if still no result! run a full recovery of the operational system to factory settings.
Mar 13, 2012 | Lenovo IdeaPad Z570 Notebook
While driving my 02 spectra it drops rpm and shakes if i hit gas petal but wont gas up either what is wrong nothing shows on computer diagnostics
Someone broke into my 2002 Spectra,stole the radio and messed up the dashboard,now it won't start what is the problem?
Apr 25, 2011 | 2002 Kia Spectra
I have a monitor display that is shaking. How do I fix it. Donna
Move any computer-speakers further away from the monitor -- the magnetic fields in the speakers can affect the screen.
Also, move any power-bars away the monitor.
Take the monitor away from the computer, and connect it to a different desktop/laptop computer, to see if the "shaking" follows the monitor.
Try a different monitor with your computer, to see if the computer's video-card is the cause of the problem.
Aug 19, 2010 | Gateway Computers & Internet
Display on my monitor is shaking. I checked the videocard and even the power supply but it still didn't stop from shaking. I even try to use different monitor but the problem is still there.
1. Have you tried replacing your video card? If you have a back up video card use it temporarily and check if the display is still shaking.
2. How did you check your power supply? If you have digital tester then check the output voltage from the power supply connector, the yellow should read 12v and the read is 5v. If the readings is below the said standard volts, then its not stable, and you will need to replace it.
3. Last to check is the cord you are using to connect your monitor to the video card, If you have available, try also replacing this.
May 16, 2010 | Computers & Internet
Have another computer dell desktop not this one,it boots up and shows windows xp logo and then the screen goes completely black and cannot get into any thing
Possibly it is a video driver problem. Try entering boot menu by pressing the F8 key at startup, and first of all try with "Boot in last known working configuration". If it doesn't solve the problem, retry booting in safe mode and change the video resolution to 640x480 VGA. This will look horrible, but if it lets you reboot and login as Administrator in normal mode, you will be able to reinstall the video drivers from Dell (either the CD-ROM or the web site). At that point you will be able to raise the resolution again.
If it still doesn't work you might need a recovery install of XP, which sometimes messes with some programs' configuration.
Oct 28, 2009 | Dell Dimension 3100 PC Desktop
Computer Desktop screen shrunk
1) First try to go into the control panel under display and try a different resolution. Or try to adjust the display on the actual monitor. If this does not help try Starting the Last Know Good Configuration.
2) The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores registry information and driver settings that were in effect the last time the computer started successfully. Use the Last Known Good Configuration feature when you cannot start Windows XP after you make a change to your computer, or when you suspect that a change that you just made may cause a problem.
How to start your computer by using the Last Known Good Configuration feature loadTOCNode(2, 'moreinformation'); To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER.
Sep 21, 2009 | E-Machines eMachines Desktop PC
Game crashes
It might be your graphics card or one of the files is corrupted try installing it again and if it still crashes its your computer
Feb 06, 2009 | HP Hewlett Packard Pavilion S3530F Phenom...
ATI RADEON  9250, (256 MB) PCI Graphic Card Logo
185 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
