Question about Kenmore Kitchen Ranges
The "stainless steel" coating on my Sears Kenmore Micro wave (model 721.85063010) is peeling. I'm unable to locate a replacement handle (no longer available). How can I recover the handle?
4 Suggested Answers
SOURCE:
IFIXALL
  • 869 Answers
SOURCE: Stainless Steel Cover for Grill
Yes the parts are available .As for the removing the material left on the cover,I would use a very light 400 sandpaper first to see if that makes progress.Without seeing the cover it's not advised to give any advice, only because without the right pressure and tool used it will vary on how this will be removed.
Posted on Jun 24, 2008
SOURCE: exterior finish on stainless steel model peeling
Just a thought. Our frigidaire stainless steel refrigerator came with a temorary protective film on the steel parts that we peeled off after it was installed. Is it possible you never removed your film when you got your refrigerator? That may be what is starting to peel off now. Again, just a thought, I could be wrong.
Posted on Sep 02, 2008
  • 10865 Answers
SOURCE: Stainless panel for Kenmore 3631532 dishwasher?
I have two options for you to consider. One is to take your panel to any sheet metal fabricating shop and have them make a stainless steel version for you. The other is to get a spray can of stainless steel appliance paint and apply it. i have used the stainless steel paint on entire appliances with excellent results.
Posted on Jun 05, 2009
Frigidaire Gallery Stainless Steel Appliance finish defect. The Smudge-Proof finish on my Frigidaire refrigerator began peeling off after I owned the product for 14 months. It appears to be a clearcoat...
Frigidaire Gallery & Professional appliances put a micro-coating over their brushed stainless to help prevent smudges and fingerprinting. However, if this coating has begun to peel off there isn't much you can do about it. You can order a new door for it for around $250-$400 depending on the door. Very rare for this to happen. If was a common problem, they wouldn't make it like this.
Oct 17, 2013 | Refrigerators
Microwave sometimes heats up food and sometimes it does not.
usually when you kill the power and then when you put power back on the machine works it's the computer board that's bad.all you're doing is resetting the board just like your house computer,if something happens to it you shut it down and reboot it,that's what you're doing with the micro wave just rebooting the board.here's the funny thing about micro waves sometimes the part you're gonna change is almost the same price as a new micro wave so i would first check how much the board is,i went on sears and they have the board for 115.00 repair clinic for 235 part number WPW10216347 they don't make this model anymore but you can get a stainless micro for around 290 to 300 dollars and if you buy the same brand all you should have to do is remove the bolts up above that hold it in place and remove the micro wave and the same brand should mount the same way so you won't have to drill new holes or replace the back metal panel.if i were you i would replace the unit instead of the board repair clinic shows most of the parts for this model out of stock so it might be a while before you can get any parts for this model but this is up to you.good luck with your micro wave.one more thing when you were in there did you see alot of grease,this is usually the cause of no heat,the grease from cooking on the stove top gets into the micro wave and on the mag tube and damages it,if there was grease in there i would just replace the unit
Dec 15, 2017 | Whirlpool WMH2175XVS Stainless Steel 1000...
Converting color appliances to stainless steel
Yes you can get black control panels through an appliance parts supply store. You will need the make and model number of your dishwasher and you will have to specify that you want the control panel in black.
Oct 01, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Jun 05, 2009 | Dishwashers
Finish on "stainless steel" door is deteriorating
Refrigerator was sold as 'stainless steel', but is not, a magnet won't stick to it.
There are many different alloys that are called 'stainless' steel but all of them have some chrome, some nickel and some steel. Depending on the strength of the magnet and the specific alloy, it may or may not adhere. Generally, the higher chrome and nickel content, the less magnetic it will be.
I think that the brushed surface of your fridge was coated with a kind of clear-coat to prevent fingerprints from adhereing to the brushed surface and that clear-coat is now missing in the areas of concern.
The only cure for tha would be the wholesale removal of the doors and the remaining clear finish and then respraying it with a quality clear finsh.
Ain't progress grand?
We considered all stainless stuff for our new home a couple of years ago, decided we liked black better and now hate that too.
Dec 10, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Exterior finish on stainless steel model peeling
Aug 21, 2008 | Frigidaire FRS-26DR7D Side by Side...
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
