Question about Canon NP 6035 Copier
Troubleshoot I have problem with NP 6035, the problem is E065
Désolé car j'ai le méme problème et je trouve pas de solutions, un code d'erreur E065 puis ca bloc avec un bourage, c'ent ambétant car ca me fait perdre beaucoups de papier. merci de m'aider
Posted on Nov 07, 2009
It will be the pre tranfer roller guide out of position or it will be composite power supply pcb
Posted on Nov 28, 2007
2 Suggested Answers
SOURCE: E065 error
E codes are usally associated with copy jams check all paper drawers for paper jams and display panel indicator to see what area is lit and then check that area for trapped paper.
Posted on Jan 15, 2008
Canon NP 6035 Error code &switch on and off
What is the error code is displayed on the control panel???
Oct 01, 2011 | Canon NP 6035 Copier
E065 canon NP 6030
If I rember correctly, Your transfer roller unit is arching out. I would first clean off the loose toner in the unit & from the seperation unit. You will need to remove the transfer roller unit. If that dos not clear the code you will need to replace the transfer roller unit. Good Luck
Mar 10, 2011 | Canon NP 6035 Copier
CANON NP 6035 The error code E224
Bagaimana cara mengatasi error e224 ???
Salam Sukses By KBG.
Feb 27, 2011 | Canon NP 6035 Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
Trouble E065 WITH CANNON 6230
ERROR E065-Composite Power Board or DC Controller
Jan 11, 2010 | Canon NP 6230 Copier
How to replace the cleaning web in Canon NP 6035 copier?
You must remove the fixing unit and just look how is assemblled and dissass. it or you can call the service
Jan 09, 2010 | Canon NP 6035 Copier
Canon np 6035 saya tak menyala tombol start di posisikan on mati sekitar 5 detik mati sendiri
Mesin canon NP 6035 kalau dinyalakan keluar kode E 224,kenapa yaa????mohon bantuanx....thanks.....
Oct 01, 2009 | Canon NP 6035 Copier
Printing on Canon NP 6035
I check www.usa.canon.com and couldn't find anything that came close to that model number. You should contact them directly. It may require a copier dealer in your area to get one for you.
Jun 26, 2008 | Canon NP 6035 Copier
E065 error
Jan 15, 2008 | Canon NP 6035 Copier
Canon NP 6035 Copier Logo
311 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
