Question about Whirlpool GHW9150 Front Load Washer
Washing machine hi please help my washing machine is not working properly it won't drain the water away or spin properly
  • Sammie12 Mar 09, 2008
    Same. My GHW9150P front won't drain either. I run the manual drain recommendation from the owners manual (drain cycle for 12 minutes). But it stops after 10 minutes with an F02 error message. Am directed to then look for a kink in the drain hose, but that's not the problem. Help!
    President:
  • 1,294 Answers
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Posted on Apr 01, 2009
    Problem Solver:
  • 3 Answers
Listen to premm.....We just used his solution, and now our machine works just like the first day we got it! Good luck!
  • 164 Answers
You don't say if it is a front loader or a top loader. my guess would be a top loader and it is probably a belt problem
Posted on Nov 28, 2007
Fast spin not working. drum going round and draining but not spinning. Help!!!!
Possible there is no drive voltage to the motor at this point of cycle, could be due to fault in the controller unit.
Need to check the voltage on the unit to confirm this case as the drain gets connected..
Jul 27, 2012 | Hoover Washing Machines
Hi my hotpoint ultima wmd960 of 2 half years,when i put a wash on it starts and fills up for about 3 mins later it comes up :no water, check supply, then starts ti drain water away ,then fills up again,so...
Please check your inlet water hose for any clogging that may be stopping the proper flow. some machines are programmed to get filled in particular given interval of time. they need proper pressure to properly work. Remove the hose and clean the wire mesh filter.
Oct 02, 2017 | Washing Machines
Roper washing machine fills and washes, but when it gets to the spin cycle there is no sound and it won,t spin.
Hi m3gamma1,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Washing Machines
The machine won't go into spin cycle
Hi badams1,
Kind Regards
JEDEMEYER1
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards
JEDEMEYER1
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
You may need to clean the Drain Filter, please find my Tip below on the procedure:
Kind Regards :-)
JEDEMEYER1
Aug 01, 2011 | Samsung Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
The machine won't spin. you can hear the motor working. I have empied all excess water out and checked if anything is court in the machine. can you please help
heatman101
May 11, 2011 | Washing Machines
My AWG 320/2 doesn't seem to be draining away the water properly at the end of a cycle. Any idea what the problem might be.
heatman101
Jan 23, 2011 | Whirlpool AWG320 Front Load Washer / Dryer
Whirlpool GHW9150 Front Load Washer Logo
227 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
