Question about Bionaire Dryers
My Bionaire BT440RC quit blowing air....how can I fix that....all buttons work...tower rotates...
SOURCE:
  • 883 Answers
SOURCE: Fan will not work
open it. look for a wire that has become disconnected from careless factory assembly
Posted on May 20, 2007
protek480
  • 1730 Answers
SOURCE: my lasko tower fan gets power n wont blow air
The bearings on the motor are dry and need oil. It's really not made to be oiled, but you may be able to take it apart and get some oil to the bearings if you want to mess with it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 22, 2009
  • 55 Answers
SOURCE: It dont blow out air,,doe;tsclean air quite
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Posted on Sep 13, 2009
  • 4 Answers
SOURCE: Bionaire upright fan stopped blowing air
Throw it away. I have come to conclude that Bionaire is a junk brand that does not service their products. I have a bionaire model BCM646 humidifier purchased at COSCO and the water tank broke.
NO! I did not drop it, it just sat in the corner. I have not even used all the factory filters that came with it.
Who would have thought a made in China product (for American idiots) would break and not have replacement parts?
Such a shock considering their fine reputation.
Posted on Jan 09, 2011
SOURCE: bionaire space heater Model# BCH9208 blowing cold air
buy an original I- heater at originaliheater.com. they are the bomb with a lifetime warranty
Posted on Jan 14, 2012
Bionaire heater sometimes turns on at very low intensity and just kind of chugs along as the yellow button flashes. It works fine just wondering why it does that
Amazon.com - Bionaire Heater with Rotating Grill ...
www.amazon.com > ... > Space Heaters
Amazon.com, Inc.Amazon.com - Bionaire Heater with Rotating Grill, BFH2242M-SM - Space ... The ultraquiet Bionaire® Heat Circulator with Rotating Grill circulates warm air ... High-intensity, sun-like warmth, Gentle heat, Medium intensity, whole room .... When temperature reaches what you have set it to, the heater turns off and sometimes.
Bionaire Office Heater with Worry Free Motion Sensor
www.amazon.com > ... > Heaters & Accessories
Amazon.com, Inc.
Rating: 4.4 - ‎71 reviews
Amazon.com - Bionaire Office Heater with Worry Free Motion Sensor - Space Heaters. ... Heat turns off after 30 minutes of no motion detected. ... If you place it under the desk, your feet will be very warm, but not so much the rest ... CONS: The High setting gets too hot sometimes, while the Low setting doesn't get hot enough.
Bionaire® Electric Fireplace Heater BEF6500-UM - Bionaire
www.bionaire.com/bionaire-site.../bionaire...heater/BEF6500-UM.html
The Bionaire® Electric Fireplace Heater provides the ambiance and warmth of a ...Flame Intensity; 12 Hour OFF Timer; Free Standing or Wall Mountable; 2 Heat .
Jan 30, 2016 | Bionaire Heating & Cooling
How do I clean a Bonaire oscillating tower fan btf4002
The easiest way to to use pressurized air. Buy a can or use compressed air.
May 23, 2014 | Bionaire Slopeflow 40" Tower Fan with...
How to change remote control battery for a Bonaire heater
The remote for Bionaire® 20" Ceramic Mini-Tower Heater with LCD Control uses BUTTON cells (Disc type, 3 volt, CR2025)..
Open the remote as shown in page 4
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/-/Sites-bionaire-ca-Library/default/dw869fb9a8/documents/instruction-manuals/BCH9208-CN_EN.pdf
Jan 12, 2014 | Bionaire BT200RCU Tower Fan
My bionaire was accidentally kicked to the floor and now doesn't work. Thank you
Are you asking for donations to buy a new one? Call the factory, most likely you will need to send it in for repair.
Jan 06, 2013 | Humidifiers
Bionaire bch9221-um tower heater is still creating hot air but I think the fan is not blowing because it is not making that whirr sound that it usually makes and the hot air smells like it is burning on...
Hello christillejo,
A total CLEANING works wonders...!!
Check the fan for VOLTAGE... If present & ...
If it is not running... shut it all down... and clean your fan parts with at least 70% alcohol... blow it dry and set it aside while you find your HIGH-GRADE (CLOCK-TYPE) silicone oil...
Put a wee bit (oil) on your freshly cleaned bearing surfaces.
While the FAN might not run a complete 15 to 20 years it did before... this procedure can add years to your FAN'S life-cycle.
In the meantime... check your OPTIONS for an opportunity
appliancepartspros
Search Over 2 1 Million Appliance Parts
repairclinic
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Partsselect
PartSelect Appliance Parts and Repair Help
Carnac the Magnificent
Mar 21, 2017 | Bionaire Ceramic Tower Indoor Space Heater
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
Lasko ionizer tower fan works but does not blow air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} I had a similar fan which quit. I could sometimes get it to start spinning by banging on it. Finally took it apart. Lots of small screws, all small phillips. As I suspected, the "thrust bearing," which supports the rotating components, had become "stiff." I thought that it would be a non-friction (ball bearing), but it is only a bushing, with washers supporting the shaft. With the motor opened up, I greased the bearing with petroleum jelly, and reassembled everything. It is spinning very quietly now. Final comment - this is probably more work than the average fix-it person would want to take on, but it is doable. It took about two hours, start to finish. I could do it in less than one hour now that I know how to do it.
Aug 01, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
Apr 01, 2009 | Bionaire BT45RC Tower Fan
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Dryers Logo
50 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
