Question about Kenmore Refrigerators
Diagnostic mode for kenmore elite refrigerator
Need to see if pressing certain buttons on my fridge will put it into diagnostic mode and allow me to see what is wrong with it by displaying a code "Woke up to a thawed freezer and cool fridge. Kenmore Elite model #: 795.71039.010. I regularly clean it, meaning the condenser and the stuff where dust builds. I do a yearly blow out of the undercarriage too. I have unplugged it for 5 mins and also i took electric back panel off, found the reset button and did that and let it cycle. As of now, temp is holing in the fridge at 34 (I have it set there) and im attempting to get temp from the freezer. Have seen other models by Kenmore have a way to press a couple of front buttons to let it go into a diagnostic mode where it pushes codes if any, and then i can look them up."
    Passionate:
    Visited the website for 10 consecutive days.
  • 128 Answers
Some do have a diagnostic mode and some do not. Each model is different and we really need to have a model# to help troubleshoot any issues. You also did not say what the issue is?
Posted on May 12, 2019
Testimonial: "Woke up to a thawed freezer and cool fridge. Kenmore Elite model #: 795.71039.010. I regularly clean it, meaning the condenser and the stuff where dust builds. I do a yearly blow out of the undercarriage too. I have unplugged it for 5 mins and also i took electric back panel off, found the reset button and did that and let it cycle. As of now, temp is holing in the fridge at 34 (I have it set there) and im attempting to get temp from the freezer. Have seen other models by Kenmore have a way to press a couple of front buttons to let it go into a diagnostic mode where it pushes codes if any, and then i can look them up."
  • Paul Denton
    Paul Denton May 16, 2019
    Refrige not throwing codes. Took off back electrical panel exposing mother board. On the board was a reset button. Reset the fridge 3 times over a course of an hour. Display was either all 2's or 3' and loud beeping. After last reset beeped loud then began normal operations. Has been working fine for over 4 days. Just FYI in case anyone else runs into this problem.
SOURCE:
  • 1073 Answers
SOURCE: Remove Doors on Side by Side Kenmore Elite Refrigerator with water tube
this is the new style connectors push in on the blue end of the connector and pull on the hose it will come out of the quick connect connector
Posted on Apr 25, 2008
jonniewalker
  • 1031 Answers
SOURCE: Kenmore ELITE error code ER FF
ER FF error is malfunctioning evaporater fan
hope this helps
Posted on Oct 18, 2008
  • 8 Answers
SOURCE: Kenmore Elite Trio electronic panel displays 'Er IF' and touch buttons not working
I have the same problem!
Posted on Nov 04, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
SOURCE: My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Posted on Feb 24, 2010
Start button will click but won't start
Hello. Your model dryer has a service flash on the lower door strike/catch concerning not staying closed or not closing properly. If the door is allowed to open too much, the door switch will not be closed and the dryer won't run. The part number for the new kit is 279570 and it includes 2 door strikes and several catches. You choose the ones you need. However, if the door *is* closing properly, you can put the unit in diagnostic mode(door closed, all indicators off) by pressing/holding any button *except* stop for 2 seconds, then releasing, press/hold 2 sec, release, press/hold 2 seconds, release-- all the indicator lights will light for 5 seconds, and an 8 88 will be shown in the display. If there are *no* active fault codes, the indicators will momentarily turn off and then stay on with the 8 88 displayed. If there is an active fault code, it will be flashing in the display. (ex. would be an "F" and "xx" where "xx" would be a number.) If you press the same button you originally pressed once, then again, then again, the most recent code will be displayed, then the next, and so on up to 4 stored codes. To turn off diagnostic mode, just press stop. I hope this helps you!
F01 PRIMARY CONTROL FAILURE
F02 KEYPAD
F22 OUTLET THERMISTOR OPEN
F23 OUTLET THERMISTOR SHORTED
F24 INLET THERMISTOR OPEN
F25 INLET THERMISTOR SHORTED
F26 MOTOR DRIVE SYSTEM FAILURE
F28 MOISTURE SENSOR OPEN
F29 MOISTURE SENSOR SHORTED
F30 RESTRICTED AIRFLOW
F70 NO COMMUNICATIONS BETW ELECTRONIC ASSEM
F71 " " " " "
F72 THRU F78 CONSOLE ELECTRONICS FAILURE
Aug 23, 2015 | Kenmore Dryers
Changed battery now radio doesn't display song or artists name. How do I fix this?
Once you disconnect the battery everything that is in your memories goes "poof" it will take a little time for all of your stations to come back. If I'm not mistaken you still have to set those manually. Radio is mostly satellite that's why you get song names etc. So drive let the computers collect data and before to long you'll get to see this names come up again. Hope this helps.
May 04, 2015 | 2010 Ford Edge
Washer will not run or complete a diagnostic.
1. The washing machine needs to be plugged in and in stand by mode with all indicators off.
2. Choose any one button on the washer's console except Power, Start, or Stop. Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds - Release 3 Seconds - Press/Hold 3 Seconds.
3. If the diagnostic test mode has been successfully entered, all of the indicator lights will glow for five seconds with 88 on the time display. (If it didn't work try #2 again One one thousand...Two one thousand...Three one thousand)
4. If there are any saved fault codes they will be displayed. If there are no save fault codes all indicator lights will turn off for a moment then back on with 88 displayed and the automatic diagnostic test mode will begin in five seconds.
5. If you are unable to enter the diagnostic test mode, press the power button and verify that the button you were trying to use operates properly to program the washer's cycle function. There may be something wrong with that function button. Find another button on the control that appears to work and try to enter the diagnostic mode with that button. You may also want to verify that the user interface has a good connection to the washing machine control board at the P11 terminal.
Back to Top
Note: Pressing the STOP or POWER button at any time to exit the washing machine's diagnostic mode.
Mar 14, 2015 | Kenmore Washing Machines
Where is the reset button on a hottpoint side by side refrigerator.
Self Diagnostics
To enter Self Diagnostic mode, both temperature control panel displays must be illuminated. A display can be illuminated by pressing an adjacent temperature adjustment button. When both displays are illuminated, set the freezer and refrigerator temperature settings to 5. Simultaneously press and hold all 4 temperature adjustment buttons for approximately 3 seconds. A flashing 0 in the refrigerator and freezer displays will indicate that the refrigerator is in Self Diagnostic mode.
To perform a self diagnostic test, locate the test in Table 2, Diagnostic Tests.
For temperature control panels with single-digit displays, the COLDER temperature adjustment button will increment the numbers up and the WARMER temperature adjustment button will increment the numbers down. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test. Press the HOLD button for 3 seconds to begin the test.
For temperature control panels with 3-digit displays, the COLDER temperature adjustment button will increment the numbers down and the WARMER temperature adjustment button will increment the numbers up. Use the freezer temperature adjustment buttons to enter the test code number in the freezer display. Use the refrigerator temperature adjustment buttons to enter the test code number in the refrigerator display. When a test code has been entered, the displays will flash to confirm the test code. Press any button other than a temperature adjust button to begin the test.
When testing has been completed, do one of the following things:
• Enter code 1 5 to completely reset the system.
• Enter code 1 6 to exit diagnostic mode. The temperature control panel is reset automatically.
• Unplug the refrigerator for at least 10 seconds. Test mode will terminate when the refrigerator is plugged back in.
Test mode will terminate automatically after 15 minutes of inactivity.
Read more: http://appliancejunk.com/forums/index.php?topic=10408.0#ixzz3VIqUINVz
Feb 27, 2015 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a 2006 ford fusion which the radio system
Inspection and Verification
  1. Verify the customer concern.
  1. Visually inspect the following for obvious signs of mechanical or electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Antenna
  • Antenna cable
  • Door trim panel(s)
  • Speaker(s)
  • Noise suppression equipment
  • Smart junction box (SJB) fuse(s):
    • 12 (7.5A) (accessory delay feed)
    • 17 (20A) (subwoofer amplifier) (Audiophile)
    • 18 (20A) (audio unit hot at all times)
    • 22 (7.5A) (audio unit hot in START)
  • Battery junction box (BJB) fuse(s):
    • 20 (20A) (LH audio amplifier) (THX®)
    • 21 (20A) (RH audio amplifier) (THX®)
  • Circuitry
  • Digital signal processing (DSP) module (THX®)
  • Subwoofer amplifier (Audiophile)
  • Audio amplifier(s) (THX®)
  • Audio unit
  1. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
  1. If the cause is not visually evident, connect the diagnostic tool to the data link connector (DLC) and select the vehicle to be tested from the diagnostic tool menu. If the diagnostic tool does not communicate with the vehicle:
    • check that the program card is correctly installed.
    • check the connections to the vehicle.
    • check the ignition switch position.
  1. If the diagnostic tool still does not communicate with the vehicle, refer to the diagnostic tool operating manual.
  1. Carry out the diagnostic tool data link test. If the diagnostic tool responds with:
    • CAN circuit fault; all electronic control units no response/not equipped, refer to Section 418-00 .
    • No response/not equipped for the audio unit, Go To Pinpoint Test A .
    • NOTE: Do not press any buttons on the audio unit while the audio unit is carrying out the self-test. System passed, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs, and carry out self-test diagnostics for the audio unit.
  1. If the DTCs retrieved are related to the concern, go to Audio Unit Diagnostic Trouble Code (DTC) Index.
  1. If no DTCs related to the concern are retrieved, and the concern is not visually evident, proceed to the Speaker Walk-Around Test and the Audio Unit Self-Diagnostic Mode.
NOTE: To enter the audio unit self-diagnostic mode, the audio unit must be turned on and in radio tuner mode (AM/FM).
  1. To enter the following tests, press the desired preset button while in the speaker walk-around test or while in the audio unit self-diagnostic mode.
  1. To exit the audio unit self-diagnostic mode, turn the key OFF or the audio unit off.
  1. If the concern remains and the fault is not detected, GO to Symptom Chart to continue diagnostics.
  1. The self-diagnostic mode has the following functions available:
    • Preset button 1 = On-Demand Self-Test. This button runs the on-demand self-test.
      • Pressing the MENU DOWN button allows scrolling of any DTCs found during the test while in this menu.
    • Preset button 2 = Display Continuous DTCs. This button enables viewing of any continuous DTCs that have been logged.
      • Pressing the MENU UP button allows scrolling of any DTCs while in this menu.
      • While continuous DTCs are being displayed, pressing the EJECT button will clear all present DTCs.
    • Preset button 3 = Signal Strength Test. This button displays the signal strength.
    • Preset button 4 = Software Version Display. This button displays the audio unit software version.
      • Pressing the MENU UP button allows scrolling of all audio subsystem software versions while in this menu.
    • Preset button 5 = Display Test. This test illuminates all the display segments for 5 seconds, then turns all segments off.
    • Preset button 6 = Configuration Status. This button enables audio unit configuration status.
      • Pressing the MENU button displays the ACM part number while in this menu.
  1. To exit the self-diagnostic mode, turn the audio unit off or turn the key OFF.
Feb 05, 2018 | Cars & Trucks
HOW DO I FORCE A HOTPOINT SIDE BY SIDE REFRIGERATOR (HSS25GFTA) WITH AN ADAPTIVE DEFROST TIMER INTO DEFROST MODE?
Start a diagnotsics mode and enter test code 1 - 4 of the diagnostics to start the defrost mode
Self Diagnostics
(or in your case.... after the deforst cycle completes and possibly + 15 minutes)
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | Refrigerators
My 7 year old GE Profile Side by Side will not get
Self Diagnostics
• Enter code 1 6 to exit diagnostic mode. GSS manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Need trouble shooting proceedure to enter self diagnostics for maytag neptune
From the service manual there is more to it but that was all I could put here.
Accessing Service/Diagnostic Mode:
Pressing down the damp dry and time (-) keys
for 5 seconds places the machine in the
diagnostic mode.
SPECIAL TESTS
The following table lists the various tests
available while in the Service Mode, which
can be accessed by pressing the following
keys:
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
Accessing Diagnostic Codes
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry
and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane Pad Check
While in system check mode, pressing the
damp dry and sensor dry keys for 5 seconds,
will start a membrane pad switch test.
The membrane check involves turning all the
embedded LED on the membrane pad on.
All the LED’s can be toggled off by pressing
the key associated with the LED. To exit the
test at any point, press the damp dry (>) &
sensor dry keys again for 5 seconds or press
the off key to exit diagnostic mode.
Key Pressed: Function Performed
sensor dry
Enable sensor dry circuit.
(sense dry LED) When short
circuit is detected across the
sensor bars the normal dry
LED will turn on.
start/ pause
Cycles the motor relay
on/off. When the motor is
running the start/pause LED
is on.
dry temp(^ )
If motor is running, cycles
the heater/gas valve on/off.
When the heater is regular
temp LED is on.
temperature (Co)
www.appliancehelponline.com
Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I can not get it into service mode.
There is not a "diagnostic mode" for the neptune washer.
All tests and functionality are done at each setting using the timer (except the tach circuit)
What is the problem you are looking to diagnose??
Thanks!
Mar 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Refrigerators Logo
116 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
