Question about Frigidaire GLTR1670A Front Load Washer
Washing machine Frigidaire GLW51439FSO TOP LOAD
Repacing the belt as suggested solved most of the problems. However now it does not spin washed clothes sufficiently for drying. It has a two speed motor.
    Problem Solver:
  • 10 Answers
Your door switch will cause this problem not locking it.
Posted on Dec 15, 2007
My frigidaire front load washer Model #GLTF2940E will not spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 30, 2011 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLW51439FSO top load
have you had the back of the machine off if you know how to do this take back off and then try washing machine have a look to see if the belt is slipping on the drum could be that either the drum bearing has gone or that the motor has been overloaded and needs replacing also could just be the belt first of all i would take the back off and then try machine look where the belt goes from motor to the drum check if it is slipping if not slipping open the front door and try turning the drum by hand to see how much resistance there is on the motor shouldnt be to much after you have done this let me know the outcome and i will assist you further ok ill do all i can for you but remember i cant see what your seing so you need to explain in as much detail also other experts will see what you are saying and will also offer assistance but we need as much input from you as poss ok let me know
Nov 26, 2007 | Frigidaire GLTR1670A Front Load Washer
My Frigidaire Crown Series top load washer was agitating but would not spin. It did drain the water. The lid lock did lock when it was in the spin position. It was smelling like burning belt so I...
heatman101
Mar 20, 2011 | Frigidaire Washing Machines
Our frigidaire front loader washing machine does not spin and the clothes are still wet! Model FTF1240FS2. It seems to go through the cycle and pump the water but the drum will not spin. I checked the...
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Mar 05, 2011 | Washing Machines
My frigidaire front load washer will not spin
heatman101
Jan 05, 2011 | Frigidaire Washing Machines
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
Frigidaire GLT F 2940 ES Front Load washer. Spin is slow. Clothes wet
heatman101
Sep 03, 2010 | Frigidaire Affinity ATF7000ES Front Load...
My washer won't spin. My clothes are still wet and the soap is still on them at the end of the cycle. Do you think it is the belt?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | Frigidaire GLWS1339C 3.0 Cu. Ft. Top...
Will not spin and belt is in good condition
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 17, 2010 | Frigidaire FTF2140F Front Load Washer
Smoking burning rubber smell from machine
Welcome
You said, frigidaire GLWS1349AS1 TOP LOADING WASHING MACHINE
pls help - is the machine done with- it set the smoke alarms off ???
Sounds like the belt is loose and smelled like rubber burning from spinning fast!
Change belt
Let me know.
Please remember to leave a rating
Oct 06, 2008 | Frigidaire GLWS1339CS Top Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
