Samsung dvd r136
My dvd recorder has started not playing some discs that it used to,it just tries to load and does nothing,would cleaning the lser help>
  • 1 more comment
  • lusly Dec 06, 2007
    dvd disc will not play
  • Anonymous Dec 23, 2007
    It is not possible to load any DVD's into the machine. It just says loading and then after about 30 seconds goes to "set up" and locks up. Tried factory reset etc. but can't get anywhere.
  • bazza74 Jan 11, 2008
    no fix yet,ive cleaned the laser and it still doesnt work?
    anyone?
This is happening to me for the second time on the same unit. The first time, I brougt it back to the store and the GeekSquad took the cover off while I was there to watch. He demonstrated that when inserting the DVD it would try to load, but the DVD would not spin. The tech manually spun the DVD in clock-wise direction and the DVD "caught on" and the DVD loaded successfully.
This was not the recommended approach for loading DVDs, and it did not make loading start to work again (except by manually spinning the DVD again). Also note that this situation seems to "degrade", not improve over time.
Fortunately, the first time I was able to get the unit fixed under warranty ... I am not sure what I am going to do about it this time.
I hope this helps some of you out there experiencing the same problem.
Posted on Mar 16, 2008
I have the same problem with mine have found a solution yet?
Posted on Jan 08, 2008
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
Samsung DVD-R130 will not load dvds, but will play CDs
Hey,
have you tried a lens cleaner? the lens may have gone bad and would need to be replaced. Do you have warranty on the player?
Sep 02, 2008 | Samsung DVD-R130 DVD Recorder
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
I HAVE A SAMSUNG DVD HR753 WHICH HAS 160 HARD DRIVE
Make sure you are using the right disk IE, DVD-R or DVD+R. Most Newer DVD player's will play DVD-R but very few play DVD+R
Jun 23, 2009 | Toshiba SD-6200 Multi-disc DVD Player
Dvd will not record
Hi and welcome to FixYa,
Initially, try to clean the lens using a CD disc cleaner. Additionally, verify that your blanks are either DVD-R or DVD-RW.
Pls post back result(s). Good luck and Thank you for using FixYa.
Jan 16, 2009 | Samsung DVD-R130 DVD Recorder
Samsung DVD-VR320 DVD wont record and shows EC0509
Try cleaning the lens. A commercial lens cleaner should do the job, but if not, contact me again, and I'll try to help you clean it manually
Jan 04, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
I have a Samsung dvd-r136 will not play any dvd. On screen it says disc not recognised check disc. I have cleaned with dvd lens cleaner but made no difference
I also have a Samsung r136 but have rarely used the DVD player. It went past the warranty and has given up the ghost. It will take discs in but I just get a spinning sound and it won't play anything For a while if I reloaded the tray it would work on perhaps the fifth, sixth, then tenth etc. time. Now it's shagged and won't recognise any disc I put in. Anyone got a suggestion?
Nov 18, 2008 | Televison & Video
Will not playback get error message Please Check Disc
i have a r136 , have you got the dvd discs u need ? i had the wrong format .
eg, dvd+rw needed dvd-rw
if not and there re-recordables they dont work after a few recordings and u need a new disc.
Dec 05, 2007 | Samsung DVD-R130 DVD Recorder
I just filed a complaint with Better Business Bureau against Samsung. Would anyone be interested in joining me in the complaint?
Nov 09, 2007 | Samsung DVD-R130 DVD Recorder
Samsung DVD-R135 / R136 - Will not load blank discs
Hello, First be sure your using the correct disc DVD+ or DVD- RW etc.
I would recomend using high quality discs as players/recorders are very picky about cheap media. Try using Imation name brand discs. They read well in most anything. If it has worked fine & then started having this problem I would first check to see if your using the same discs that have always worked with it & if so then you may want to open the unit & clean the laser lens with a cotton swab lightly soaked in rubbing alcohol. Especially if it has been smoked around or is in a dusty environment.
Feb 15, 2007 | Samsung DVD-R135
Open Questions:
Televison & Video Logo
382 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
