Question about Car Audio Receivers
Sony Car Stereo Removal
I have a Sony Car Stereo that won't stay on. I'm sure it is just a loose wire, but I don't know how to remove it from my '95 Ford F-150 dash. My son bought me these two flat tools specific to Sony, but I can't figure out how to use them? Is there a 'standard'? Or do you need my model number to give me direction? I am sure the stereo was installed prior to 2003, but after 2000. Thanks in advance to anyone who tries to help!
SOURCE: 2008 Suzuki SX4 Factory Stereo removal
Aparantly you need to carefully remove chrome strips either side of stack. I just found this out today and haven't done it yet to see what kind of plug it has at the back(so if you find out please tell me)
Posted on Aug 30, 2009
0 characters
1 Points
Jvc car stereo warning wiring chk then reset unit
MISWIRING OR CHKWIRING is displayed when there is a DC offset voltage detected at the speaker terminals ('+' and '-').
This is normally caused by connecting a '+' or '-' speaker wire to either GND or Vcc (+12V).
1. Collect cable not being used and make sure they are tapped off and reset
2. Remove a connected cable one at a time and press RESET
3. If after a cable removal and reset the error goes away, last cable removed was fault. Examine cable for short.
4. If you remove and reset all cables except for (RED, YELLOW, and BLACK) and you stilll have error, the short is internal of unit and requires service
Need code for sony cdx-l480x eq3 stereo
There is no code for resetting a radio. If there is not reset switch, you can reset a radio by disconnecting power to it for a few seconds. This can be done by either disconnecting the wire harness behind the radio, or if you don't know how to get the radio out of the dash, you can disconnect one of the terminals of the battery for a few seconds.
Oct 02, 2012 | Sony Car Audio Receivers
Have a jvc kd-sc401 connected 10 disc multichanger but won,t load cd,s although you can hear multi changer trying to work pls help.stereo working as should don,t have manual for stereo so don,t know how to...
You need to reset the CD player. Remove the front panel and you will see a tiny hole in the middle of the panel of the unit mounted in the dash (i.e. without front panel). Gently push a ball point pen or pin in to press the reset switch.
About the User Manual, visit the next link to download: kdsc401-402e_get0410-001c_fr (pdf)
Hope this helps.
Hi, I recently purchased a new Stereo deck and I like to remove the old Alpine CDE-7827 deck. My car is a 1995 Ford Thunderbird.
The original wires in the 95' thunderbirds are a pain, trying to figure out how to take out factory stereo and replace with aftermarket Sony cd player, have no clue because the wires don't match up, some do and they will load and unload discs but won't power up any suggestions...?!?
May 24, 2011 | Alpine CDE-7827
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
Need 2 know what my wiring on my car stereo goes to i need color codes on a 95 lincoln town car
Go buy a wiring harness from Car Toys. After you clip in the harness it is all color to color matching from there.
Remove a 2004 focus stereo and replaced it with a new stereo
purchase the following: ford radio removal tools installation kit wiring harness the included instructions will make it a simple process.
May 19, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Faceplate has very loose connection
make sure there is no dirt between the metal connections. on my kenwood, excessive removal of the faceplate caused a little dirt build up...check this and itll probably solve your problem
Jun 25, 2009 | Kenwood KDC-MP435U CD Player
CDX-RA700 will not get power from my Honda Civic
Automobiles use Direct Current "DC" and is very dependant on a good ground. The black wire from your stereo should be the ground and needs to be attached to the chassis "metal part of the car". You can use an ohm meter to check for grounds by placing one lead on your door hinge (unpainted) and the other to where you are connecting your ground from the stereo. Be sure that this wire does not have voltage on it with the key off, on acc, or in the on position or you could blow a fuse or damage your equipment. Besides that make sure that you have 12v constant to the (usually red wire) and switched (voltage only with the key on) to (usually the yellow wire). Hope that helps. It's mostly about the ground.
Mar 10, 2009 | Sony CDX-RA700 CD Player
Car stereo installation
I had this problem as well. On my harness was a wire for connecting the factory amp. You have to connect the Automatic Antenna wire to the Factory Amp Turn On wire. Should be a blue wire to a blue wire with a white stripe.
Oct 15, 2007 | Car Audio Receivers
Car Audio Receivers Logo
1,309 people viewed this question
Top Car Audio Receivers Experts
xxxxxx xxx
Are you a Car Audio Receiver Expert? Answer questions, earn points and help others
