Question about Samsung Televison & Video
Was having solar installed With that said, all I did was to unplug all electronics, also why this TV was off, from the outlets so as not to have any power surge from the conversion now TV wont turn on
So makes no sense that just unplugging the TV, again while TV was turned off, from the outlet should keep the TV from turning back on. Samsung HD TV 32" Series M4500 Model # UN32J4500AFXZA
SOURCE:
SOURCE: Model F27650 RCA Entertainment Series
I have a RCA Entertainment Series 32' Model Number F32650Y01E024C226E just stopped working. no picture, just a chirping loud noise that came from the back of the tv.
Any suggestions?
Posted on Jun 23, 2008
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
  • 17 Answers
SOURCE: 27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
do you get extension corn in Iowa?
Posted on Jul 15, 2009
SOURCE: My 42HDS69 Hitachi has a recurring problem of not
MY TV KEPT GETTING WORSE EACH DAY ALSO. BUY A CAN OF SPRAY AIR WITH THE EXTENSION SPRAY TUBE. WHEN YOU GET THE TV RUNNING SPRAY THROUGH THE HOLES IN THE BACK RIGHT ONTO THE FAN BLADES OF BOTH FANS. THE DUST WILL FLY OFF THE BLADES. A VACUMM HOSE WILL HELP PULL OUT THE DUST. ALSO SRAY THE POWER SUPPLY BOARD FOR DUST. I APPEARS THE FANS SLOW DOWN WITH DIRT ON THEM AND THE EXTRA HEAT BUILD UP JUST AFTER THE TV IS SHUT DOWN IS CAUSING THE POWER SUPPLY TO BE IN A SHUT DOWN MODE WHEN POWERED UP THE NEXT TIME. BEEN TWO WEEKS NOW AND WORKS PERFECTLY NOW AGAIN.
Posted on Feb 11, 2010
Raditronic
  • 196 Answers
SOURCE: AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
Posted on May 06, 2010
How do i read the sungrow solar inverter eg P-ac 269w
First, I'm not a Sungrow representative.
* Contact your local solar vendor or contact Sungrow;
* Sungrow Power; https://en.sungrowpower.com/
* Sungrow Inverter MFR; http://sungrow.energy/
*** following is for information only.***
* Normaly after a PV install, there should have been a representative from the solar company (local rep) to walk you through the system features and have your internet solar monitor up and running. This app will collect all your solar data (very technical) and convert it to a "user friendly" display of power your panels and inverter(s) are producing.
* Installing instructions(Official) WiFi; https://www.youtube.com/watch?v=LVzuXssdhlI
* Installing App on phone (Official); https://www.youtube.com/watch?v=cIWINw6Ym4Q
* LCD Module User Manual; https://www.sungrowpower.com.au/files/Web_Files/FAQ/Crystal/Monitoring/eShow-UEN-Ver11-201608.pdf
* Reading digital display (Local Rep); https://www.youtube.com/watch?v=6yTziB7PVqE
* Installation w/battery (Official); https://www.youtube.com/watch?v=tKDI5jwFLxA
* Dogle WiFi setup (Local Rep); https://www.youtube.com/watch?v=6NCnLMjg9rs
* Call your solar provider for support.
Aloha, ukeboy57
Jul 21, 2018 | Inverter Electronics - Others
Will my 18watt solar panel charge a car battery and how fast?
If you hook it up correctly and the Voltages match... yes.
As for how long... THAT depends on a number of Factors... How much sun, What quality is the Solar Panel, Placement of the Panel.. the goes on and on... But you CAN charge a Battery...I charged a Battery for quite some time using a Large Solar array.... We were Camping an using the Battery for Lights Radio and Fridges.... So it CAN be done
Jan 04, 2017 | Green Living
I have a 3000 watt inverter,with 3 plug in outlet..how much power do I get from 1 outlet..this equipment is hook to 6 12 volt battery charge by a 60amp controller and 3 solar panel of 265watt each???
You didn't mention what make or model of inverter. Lets assume you are in the USA and your inverter has standard the US 15 Amp three pin 125V NEMA 5-15 AC outlets. based simply on that you would have a max of 125 x 15 = 1875 watts per outlet.
Dec 07, 2016 | Solar Electronics - Others
Tv won't switch on following power being turned off/on by electrician installing external light
Have you tried different electrical outlets? Maybe the circuit breaker for your particular outlet blew when the electrician turned the power back on. Or maybe the electrician disconnected power to that particular outlet.
Also try leaving tv unplugged for 30 minutes or so, then plugging back in [to a known good outlet] to see if it will turn on.
Apr 27, 2016 | Televison & Video
My element tv comes on but immediately shuts off
chevelestes
I would try unplugging the TV and plug into a different electrical outlet. See if the TV does the same thing. If so, it may be the TV. I hope this helps.
Ray Calo
DISH Network
Jan 27, 2011 | Element Electronics PLX4202B 42 in. Plasma...
Lots of lines on sceen, can't even see a picture. Tv is almost ne
try turning it back off. then unplug it from outlet. press and hold power button on TV for six seconds or so. Plug it back in and turn it on to see if that helped. Depleting power and memory can reset errors in today's electronics. Hope it helps
Apr 21, 2009 | Element Electronics FLX3210 32 in. LCD TV
TV won't turn back on after power cord was disconnected from unit
If power cord was jerked out of the outlet or set, make sure it wasn't damaged. If it was unplugged violently, the circuit board inside the set could be damaged. Also make sure the outlet that it is plugged into is not damaged or a switched outlet.
Aug 03, 2008 | Fujitsu Plasmavision 42" TV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
