Question about JVC Audio Players & Recorders
I have a JVC PC-XC60 boombox with a 10 CD player. The CD's load fine, but read all zeros on the digital display and will not even respond to "Play". Any ideas?
    Master:
  • JVC Master
  • 533 Answers
Its lens not working..which is inside... change it.
Posted on May 11, 2019
SOURCE:
SOURCE: JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
Posted on Aug 11, 2007
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
projdoc
  • 2237 Answers
SOURCE: my jvc cd player will not play the cd it says read
the optical pickup (lens and laser) is dirty and needs cleaning. you can buy a **** cleaner and use it regularly, but if you need it too often, you'll want to take it apart to clean it.
Posted on Jul 24, 2009
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
wracefans24
  • 1985 Answers
SOURCE: cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
Posted on Jan 03, 2010
The CD player will rotate but won't play as though it's not reading.
How to Fix your CD Player ' Librarian in Black Blog - Sarah ...
librarianinblack.net/librarianinblack/how_to_fix_your/
Well, if I was a junk pack-rat and still had all the CD players I've thrown away because they stopped ... my portable cd player lens looks to be scarched how can i fix its ... my 3 disk memorex cd player won't play any thing. it was working fine and then allof a sudden it stopped on me it won't even spin the cd to try to read.
No Disc Error, not reading CD error: Repair Sony CFD 112 ...
? 11:35
https://www.youtube.com/watch?v=iEG_u0ogjZI
Jul 23, 2013 - Uploaded by 1000uf
How to troubleshoot and repair CD player not reading disc, table of content (TOC), ... +DeathlyHall0w It's ...
How to fix a boombox CD player when it wont play - YouTube
? 5:15
https://www.youtube.com/watch?v=pH33UZveLYI
Jun 24, 2013 - Uploaded by Shyzah
If you move the boombox with the audio CD player will it slip, with this model? ... I cannot buy a new boom box ...
Why won't my disks spin? - GameFAQs
Dec 22, 2015 | Audio Players & Recorders
Why does my cd player on my Radio/Cassette/CD boombox keeps reading ncd on all my CD's even on my disk cleaner cd?
The laser assembly is not reading the disc, as the laser ages it becomes weaker until it can no longer scan the disc and can not play, you have done everything that I would have recommended, at this stage it is far cheaper to replace the boombox than replace the laser pickup assembly.
Mar 28, 2012 | RCA RCD147 CD Boombox
I've realized that the jvc rc-bx30 can't read mp3 files. I would like to burn music to a cd/dvd and then play it on my jvc. What format should i use? By the way is there a possibility to change the reader...
Indeed the JVC RC-BX30 is a model of 1999, too old to be able to read mp3 cd. As you said you can write the mp3s to audio cd and then play them from this Boombox. You have to use the typical "audio disk" format (16bit, stereo, 44.100Hz). This format is available at any recorder software (Nero for 50Euros, or Ashampoo for free or anything else you have in your mind). There is no possibility to change the cd reader in order to be able the JVC to read the mp3 cd.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 13, 2011 | JVC RC-BX30 Cassette/CD Boombox
Hi. my JVC RC-EX30 reads the CD I put into it but it wont play the songs. so the "reading eye" can't be broken so what is?
There may be a hair stuck in the sled transport gear (the sled is the part of the mechanism that moves the laser assembly and tracks the the song as it plays)
Oct 27, 2010 | JVC RC-EX30 Radio/Cassette/CD Boombox
Car cd player not working - flashing numbers...?!
sir ,
ur jvc cd player doesnot have function of normal cd . to play so cotect ur nearest car repair to help u
thanks
Jan 20, 2010 | JVC KD-G430 CD Player
JVC PC X-95 Boombox
Its moe than likely your laser. try swabbing it with a q tip and alcoholif that doesnt do it it might be the motor.
Dec 15, 2008 | JVC RX-664V Receiver
JVC XL-SV22 Video CD
if cracks having in disc mean some times header does read disc! clean your header with disc cleaner!
Jul 01, 2008 | JVC XL-SV22 CD Player
Cd player won't play discs
Maybe you should try cleaning the lens by opening the shelf TOP, and cleaning the lens? I had that problem. Take a Q - Tip with alcohol on it and it will do the job. Careful to not touch any components, and unplug first! The system can electrocute you even if unplugged, so don't touch any electronic component else than the lens inside.
Nov 28, 2007 | JVC MX-K30 CD Shelf System
Emerson PD6810 CD Boombox Error
My older model PD6810 had the spindle that holds the CD on the player missing causing the ER message to show and the player to stop working.
Aug 21, 2007 | Emerson PD6810 CD Boombox
29 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
