Question about Alpine Car Audio & Video
Alpine cde-172bt cd won't eject cd - Alpine Car Audio & Video
PUSH SILVER BUTTON TO RIGHT OF VOLUME KNOB & PRESET 6 AT SAME TIME WILL REBOOT RADIO & POSSIBLE SOLVE YOUR CD ISSUE
Posted on May 13, 2019
Testimonial: "thanks butch, it reset but cd does not want to cooperate...my dealer will swap it out...thanks"
SOURCE:
simplemitch
  • 752 Answers
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
Posted on Aug 05, 2008
SOURCE: Alpine CHM-S620 CD Changer Magazine
if you open the cage on the unit, you can pop the tray back out of the mechanism by VERY GENTLY turning the load gear on the carriage, be sure to not slip any gears on the drive or the changer will be out of sync and will be garbage unless you have it serviced by an Alpine service center. you are best to turn the 1st. gear beyond the carriage motor, or you can apply power to the motor (which I don't advise) to let the motor eject the tray. if you do choose the power method, be 100% sure of the polarity first otherwise you will damage the carriage and drive gears. the motor has a brass gear and the rest are nylon gears, the brass gear will very easily shred a nylon gear. want to be extra careful? manually turn the load motor gear itself, it will take alot longer to do, but will be the safest. I've been inside these machines quite a bit, hope I was able to help.
Posted on Sep 18, 2008
SOURCE: Connecting High Speed IPOD Cable to Alpin CDE-9874
Best Buy solved my problem.
Posted on Oct 02, 2008
etirbynnor
  • 655 Answers
SOURCE: Alpine CDE-102 w/usb port: will not
Hello desoren,
The receiver may not be set to recognize MP3 files.
Press and hold "sound setup" until the unit enters setup mode. Rotate the volume knob to "play mode" and press "enter". Check that the setting is CD/MP3 (not CD/MA), or rotate the volume knob to change the setting to CD/MP3 and press enter again. Press and hold "sound setup" again until the unit exits sound setup.
If the files are still not recognized, I'd try using a different USB drive, a different computer to write the MP3's, and/or a different application to download or rip the original music content.
Hope this helps.
Posted on Sep 23, 2009
etirbynnor
  • 655 Answers
SOURCE: i am getting a DC error on my alpine cde-102 head
Hello christo12385,
The DC error is most likely caused by a shorted or grounded speaker wire. Check all speaker wires, correct the problem, and then go into the sound setup settings and reset the POWER IC to ON.
Hope this helps.
Posted on Sep 25, 2009
Tip
Setting the clock on an Alpine CDE-9872 or CDE-9874
From the Owners Manual for the CDE-9872 / CDE-9874:
FixYa won't allow images larger than 150k, so that's why this is a little blurry.
I hope this helps!
Regards,
Char1ieJ
on Nov 18, 2008 | Alpine CDE-9872 Car CD/ MP3 Player
Hi, I recently purchased a new Stereo deck and I like to remove the old Alpine CDE-7827 deck. My car is a 1995 Ford Thunderbird.
The original wires in the 95' thunderbirds are a pain, trying to figure out how to take out factory stereo and replace with aftermarket Sony cd player, have no clue because the wires don't match up, some do and they will load and unload discs but won't power up any suggestions...?!?
May 24, 2011 | Alpine CDE-7827
Alpine CDE-9841, put in a new cd and the unit saya "NO DISK" and will not eject cd.
when you put in the disk hold down the play/pause button and to eject hold the eject button mine is doing this
Dec 10, 2010 | Alpine CDE-9841 CD Player
Alpine CDE 9870 Won't Eject Scratched CDs
Sounds like it's overheating. Does this unit have a small fan in the back? If so, does it work, or is the airflow blocked? Also, you can get 'steam' on the disc when coming in or out of the cold with it.
Jan 11, 2010 | Car Audio & Video
Put cd in and says pause and then eject. somtimes
press reset but with a pen tip ,hold for 20 secons.
Dec 26, 2009 | Alpine CDE-7828
Have removed stereo from vehicle. the stereo still has a cd inside it. How do I get the cd out
take the face off.there should be a very little hole right below were u put the cd in that u can put a paper clip in it should eject that way.if not u should be able to conect the red n black wire to a battery an hit eject
Oct 04, 2009 | Alpine CDE-9843 CD Player
Can't set clock in car I bought
set clock on my alpine CDE-9874
CD reciever
Mar 18, 2009 | Alpine CDE-9874 Car CD/ MP3 Player
Heating up on back of cde 9852 alpine cd player
try to chek the regulator or replace it and install a heatsink for him
Jan 31, 2008 | Alpine CDE-9852 CD Player
Car Audio & Video Logo
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Robert Salgado
Robert Salgado
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
