Question about Panasonic Microwave Ovens
After about 10 minutes of cooking with me Panasonic pro11 it stops and goes on F14 will I need to throw it away now
2 Suggested Answers
SOURCE:
SOURCE: Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
Posted on Jan 07, 2009
Hi, i have a panasonic inverter microwave, but stop working properly.It has power when plug-in, all function buttons are working but when it comes in microwaving, its stop automatically after 7 second
That would be an inverter issue. Here's my overview of Panasonic microwave faults:
Diagnosing Panasonic microwave oven stoppages:
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 7 seconds, it has a problem with the inverter.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
Or see if this describes what's happening:
Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector. If so, see:
http://www.microwavecontrol.com/safety.htm
http://www.microwavecontrol.com/disassembly.htm
http://www.microwavecontrol.com/doorsw.htm
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the complexity and lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Got more questions? Please contact me directly for full details since FixYa doesn't always inform us of follow-up questions. Remind me of the full model number and FCC ID number from the tag and your detailed symptoms.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Nov 25, 2017 | Microwave Ovens
How do I know wattage for 1974 recipes and convert cooking time to todays microwave (1200)
A 1974 Microwave Oven is probably not putting out more than 600 watts. You need to do a power test to determine it's actual power output. Place a 2 cup glass measuring cup with exactly 500 mL of cold water. Record the starting temperature of the water. Run the microwave on 100% power for 18 seconds, using a watch or timer, not the timer on the unit. Take the water out and stir it to make sure that there are no hot or cold spots in the measuring cup. Record the new temperature. Example: 78.4-64.1= 14.3.
Multiply 14.3 X 38.75= 554.125. The power output is 554 watts IEC. If the recipe is set for a 1200 watt unit, and your is almost 600 watts, obviously, you would double the cook time. Since this is rough, you need to experiment a bit. If the cook time is 10 minutes, check your product at 8 minutes. Be sure to push the stop button before you open the door when it is in cook mode. This will save wear and tear on door switches and leave the remaining cook time on the timer. Let me know how this works out for you..
Oct 11, 2013 | Panasonic 1974 Microwave Oven Cookbook &...
Microwave Panasonic
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://031d26d.namesecurehost.com/mwd/safety.txt http://031d26d.namesecurehost.com/mwd/disassembly.txt http://031d26d.namesecurehost.com/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That second symptom may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In other countries, visit Panasonic.net and see their support links.
Jun 08, 2013 | Microwave Ovens
Power to microwave but does not cook food
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
May 26, 2010 | Panasonic NN-H264 Microwave Oven
My panasonic inverter microwave model no NN-T523M switchs off after 5 secondsno matter what setting. the digital screen says consult manual, which has been misplaced
You can find Panasonic owner's manuals here.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If so, see http://207.234.249.73/mwd/safety.txt http://207.234.249.73/mwd/disassembly.txt http://207.234.249.73/mwd/doorsw.txt
If you decide to replace your inverter, you can order Panasonic parts from Encompass here or you can call them toll-free at 866-779-5835.
May 15, 2010 | Panasonic Microwave Ovens
Panasonic NE-1780 - F14
Could be a problem with the door latch, or the magnetron or magnetron circuit.
Aug 02, 2009 | Panasonic Microwave Ovens
If I put in cook time 3 minutes it only cooks for about 10 seconds then turns off
According to a recent report we received, if it stops after 7 seconds, it has a problem with the inverter.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 28, 2008 | Panasonic Microwave Ovens
May 28, 2008 | Panasonic NN-S262SF Microwave Oven
Microwave Ovens Logo
29 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
