Question about Motorola Mobility HS850 Consumer Headset
Pairing have lost my manual and need the code to pair my device
  • 4 more comments
  • bobbatey Nov 27, 2007
    I am replacing an HS850 with another 850 on mu e815 phone. It can not locate the replacement hs850.
  • donnet Dec 03, 2007
    motorola hs 850 would not pair with my nokia 6265i phone. it would not even find it when pairing.
  • breal16 Feb 05, 2008
    I can't find my manuel for the HS850 and need the passcode to sync it up with my phone, the Blackjack 2
  • jahrain Feb 10, 2008
    I have the motorola HS850 bluetooth and I recently got an iphone and when I try to connect them my phone will find the device but it says bonding failed? can you help?
  • Anonymous Feb 27, 2008
    I can't pair my phone
  • cuteful May 31, 2008
    I can't remember how to place my bluetooth in pairing mode.
Try 0000
Posted on Jan 22, 2008
    Problem Solver:
  • 12 Answers
  • 58 Answers
Pairing password is: 0000
Posted on Nov 27, 2007
3 Suggested Answers
PyroPCMan
  • 405 Answers
SOURCE: BT pairing code
The code is "0000", that's right, just four zero's it's that easy.
hope this helps.
http://www.pchelpforanyone.blogspot.com/
Posted on Mar 11, 2008
SOURCE: motorola hs850 bluetooth headset
take a look to this link!!!
http://www.motorola.com/mdirect/manuals/QG-HS850_9492A69A.pdf
Posted on Sep 07, 2008
Describe your pairing code for nokia ck 7w Problem i just need the pairing code
There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
May 24, 2011 | Cell Phones
Pairing
the code is 0000 when you buy it
i hope you haven't changed it
Dec 11, 2007 | Motorola Mobility HS850 Consumer Headset
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Have a nice day.
Sep 01, 2010 | Cell Phones
Bt 70r instruction manuel needed need manual or details how to pair bluetooth in car device
BT70R pairing with a new phone
The code for pairing with a new device is 0000.
However, the BT70R retains the identity of the phone that is is paired with and this old code must be removed before a new phone can be paired. There is probably something in the manual for this, but I have lost my copy. Here's how I got round the problem...
Place the BT70R in a sealed plastic bag (to protect it from moisture) and then put it into your freezer and leave for 24 hours. When you take the BT70R out it should have lost its memory of your old phone and you can pair it with the new one.
It worked for me!
Oct 21, 2009 | Car Audio & Video
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
Trying to pair omnitech 2.0 bluetooth headset without manual
before attempting to pair your headset with another device, be sure that the bluetooth headset is in the off position
  • press and hold MFB until indicator light flashes blue and red. The headset will also beep twice
  • to pair your device to the bluetooth headset use the bluetooth pairing instructions from you device's instrucition manual.
  • input ID code 0000 when requested by the device
  • the headset and device are paired correctly when the blue and red indicator light flashes blue only.
Any questions email: shyrosi@yahoo.com Subject: omnitech bluetooth
Dec 29, 2008 | Motorola Mobility RAZR V3
Troubleshooting?lost manual
Begin with headset turned off.
1. Press call control button for
6 seconds. Release button when
red. Headset is ready to pair with
Bluetooth device.
NOTE The headset can pair to
multiple Bluetooth devices, but
will only connect to one device
at a time. The headset will automatically
connect to the last
device to which it was connected.
2. While the headset is flashing red
and blue, use the phone menu
and select “3XXPlantronics”.
3. When prompted for passkey enter
0000. Headset will flash blue when
paired successfully.
Apr 15, 2008 | Plantronics Explorer 330 Headset
BT pairing code
For Cellular Innovations Mini Blue HFBLU-AX1C.
To Pair with Your Phone....
1. Turn OFF Bluetooth Headset
2. With Headset within 1 Ft of your phone, hold down power key for about 8 seconds until indicator light blinks in red and blue color quickly (in pairing mode)
3. Search bluetooth device through your mobile phone.
4. Select HFBLU-AX1C in the bluetooth device list and enter the password 1234.
Jan 15, 2008 | Cellular Innovations HFBLU-AX1 Bluetooth...
Motorola Mobility HS850 Consumer Headset Logo
216 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
