Question about Alesis Music
Schematic for Alesis Alpha 112 - Alesis Music
How to do a factory reset on a alesis s r 16 drummer
Power up while holding play-erase. BUT...when performing a re-initialization, this will erase all existing patterns, songs, and drum assignments. This will not erase the factory preset patterns or kits.
http://community.alesis.com/alesis/topics/sr-16-factory-default-reset-question
Sep 27, 2017 | Alesis Music
I need a schematic form a peavey basic 112 amp
Call Peavey Customer Service at 877-732-8391 and they'll email it to you.
Oct 20, 2014 | Music
Alesis sr 16 service manual
I got a service manual but don't know how to get it to you. I can sent it by email. Let me hear from you. Contact: petevanderwaal@yahoo.com (subject: "Manual")
The manual is for Alesis HR-16B SRV comes in PDF format.
Aug 19, 2014 | Alesis Sr 16 Stereo Drum Machine
Looking for schematic for peavey 112 ts monitor
We do not have wiring diagrams. Sorry
Mar 23, 2012 | Music
I have a Alesis Model SR-16. It turns on for about 1 min. and then turns off .
I suspect that that part MAY be a three terminal power regulator. If it is, then there is probably a near short on the buss it supplies. A common problem is a shorted bypass cap. Without a schematic this can be hard to find.
y procedure is to reduce the power inout so nothing burns, then check power at each IC on the pins and find one that is near zero then look for shorted bypass cap nearby.
Nov 18, 2011 | Alesis Sr 16 Stereo Drum Machine
Output section of PCB appears a bit fried as there is no sound output and there is a hint of burnt electronics. Rest of the SR16 works fine. I believe someone reversed the audio cable connections which...
This is your best bet:http://www.alesis.com/content1024 It will be hard to find a schematic. Here is another link:http://www.ionet.net/~tslade/sr16.htm
Aug 25, 2010 | Alesis Sr 16 Stereo Drum Machine
I own an Alesis dm6 mod. how to add cymbals.
I think your best solution is this> You can add 10 more triggers with it:http://www.alesis.com/triggerio
May 09, 2010 | Alesis Sr 16 Stereo Drum Machine
Can i hook the alesis drum machine up to my computer and use it to make beats?
Are you talking about recording the beats from the Alesis or are you talking about designing beats on your computer to load into the Alesis? If it's the latter, try this link:http://www.squest.com/Windows/Instruments/AlesisSR-16/index.html This link might also be useful:http://www.synthzone.com/alesis.htm Please let me know how you make out.
Nov 25, 2009 | Alesis Sr 16 Stereo Drum Machine
How can I put a walz beat in the Alesis
Page 59 Odd time signatures of the owners manual explains how to do this. Type Alesis SR16 manual into Google and you can download a copy from media.zzsounds.com Please rate this if it helps. You can also download documentation here:http://www.alesis.com/sr16 under DOCS and Downloads
Oct 29, 2009 | Alesis Sr 16 Stereo Drum Machine
Music Logo
41 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Harrie
Phil Whisenant
Phil Whisenant
Are you an Alesis Music Expert? Answer questions, earn points and help others
