Question about Nintendo DS Lite Console
Won't power up-flash of light on bottom screen then nothing
My son's DS started acting up yesterday. When you try to turn on the power, a bright white light flashes across the bottom screen only & then there is nothing. We replaced the battery & charged it all night, but it is still doing the same thing. He is very upset. Any help you could give would be most appreciated! Thanks.
  • jenp Nov 27, 2007
    hi, i have the same problem. Unfortunately i was trying to replace my top screen and had just put it back together. I have a feeling that either of these have happened:
    -there are two small connected wires to the top of the ds that can come loose and cause it to not turn on.
    -the fuse has gone (which from what i've read, is not good!!!)
    hope someone can help, i am going to try and re-connect everything and will let you know how it goes!
  • Whatevermack Nov 29, 2007
    Thanks for the advice. I have Nintendo sending us a remanufactured unit. My son will be thrilled!
If yr DS is less than one year old, call nintendo and ask for an advanced replacement.... they are good about it and will explain the whole process to you....the number is 1.800.255.3700.... i think it is option three for DS problems, then zero, and the will set it up.... ive had it done like three times....
Posted on Nov 28, 2007
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
I turn on my ds green light comes on bottom screen flashes then turns off
    • 1 Turn off the Nintendo DS, and place it on the charger. Leave the device for 45 minutes to allow it to gain a full charge, and then power it back on. Weak Nintendo ds lite batteries may cause screen flicker.
    • 2 Turn off the DS, and remove all game cartridges. Turn the system back on to launch the main menu.
    • 3 Click the small sun icon to open the brightness menu. Adjust the brightness level using your stylus. Turn it up to max to improve back lighting.
    • 4 Check that the Nintendo DS is open and in the locked position. It must be open to its default position to operate properly.
Apr 15, 2012 | Nintendo DS Console
My son's DS lite stopped working while he was playing. Tried good. Bought new good. When turning on the charge light turns green then the bottom screen flashes white (like it...
Hello there! First of all let me tell you that your nintendo ds can be repaired and it is not trash... what you need is to get the bottom screen to be repaired can do it sending it to the nintendo repair shop or by doing it yourself by following this youtube guide
Sep 21, 2011 | Nintendo DS Lite Console
My son spilled water on his ds lite last night. Now it does nothing. When you try to tur it on, the bottom screen flashes very quickly and thats it. Is there any hope?
If thebottom screen flashes then thetop screen is damaged and will need replacing.
You can get a new screen at a reasonable price on ebay and i have written up guides telling you how to dismantle the DS lite and how to replace the screens.
Dismantle guide (inc. tools you will need).
Top screen replacement.
If you need any further help contact me via my profile.
Feb 12, 2010 | Nintendo DS Lite Console
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
Nintendo DS lite; changed touch screen and it won't start
Hi. this issue is normaly caused by bad screen (normaly top screen) or bad assembly in one of two screens, re insert carefully the flex cable again, if your screens are fine this must fix the issue
Mar 14, 2009 | Nintendo DS Lite
Nintendo ds lite flashing top screen
i had a similar problem to this, i would check the connector strap in between the two screens if it is just one pin out this can happen
Jan 25, 2009 | Nintendo DS Lite Console
Nintendo DS lite power light comes on but both screens stay dark?
When you boot the Nintendo DS you can change the illumination settings in the main menu.
One the main menu, you will find a sunny symbol in the lower left corner of the screen. Click on that and you should be able to change the level of illumination. If you are also wondering if you can change the brightness during game play, you can't. Games such as Mario 64 DS come with support for brightness change but otherwise you have to do it before game play.
Sep 20, 2008 | Nintendo DS Lite Console
Nintendo ds problems
Not meaning to sound patronising, but have you powered it up again?? My daughter loses battery power quickly and needs to charge it often!
Mar 11, 2008 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
213 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
