Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Paper torn and jammed in the actual machine part of the printer
We knows its there but some bright spark decided to break it down with scissors. We can now not see it as the only visible bit has been cut away.
It was only a tiny bit of torn paper in the first place. It appears to have been lost into the actual mechanics of teh printer.
How do we get in there to get it out?
  • Anonymous May 24, 2008
    paper torn and jammed in actual printer.
    Novelist:
    Champion:
  • 254 Answers
I assume there must be a small piece of paper stuck somewhere in the paper path.
Do you have a pair of long needle nose pliers, or maybe a decent set of tweezers? Careful use of a long skinny screwdriver might do it too. If you cannot get down inside the printer far enough, then one or more covers will have to be removed.
Often, there are one or more screws which hold any particular cover in place, along with snap catches (for want of a better descrip). Some covers may have to come off in a specific order, like after a previous one is removed first.
Posted on Nov 28, 2007
Flashing paper and power buttons
This error means jammed paper or a foreign object is blocking print head movement. Turn off the printer, press the adjust lever down to the lowest position, and pull out the jammed paper. Open the cover and remove any jammed or torn paper, or foreign objects. Then do one of the following:
Sheet Feeder: Return the adjust lever to the position. Turn on the printer, reload paper, and press the paper button.
Manual Feed Slot: See page 15 of your manual for loading instructions.
Roll Paper: Cut off the printed portion with scissors, then remove and reload the roll paper
Mar 08, 2014 | Unknown Epson Stylus Photo R2000 Ink Jet...
The printer keeps saying that there is a paper jam when there is not.. Also some times when it trys to print it will jam and the page will be torn down the middle.
Check the machine carefully, sometins a small sliver of paper is caught in a critical place in the printer and will give the paper jam message. If you paper is being torn it is most likely due to an uneven feed caused by feed wheels that are slipping on one side while the other side still feeds normally. Clean all the feed wheels in the paper path with a Q tip soaked in Isopropil Alcohol. Also make sure that your paper guides are set to the correct widths.
Jan 21, 2011 | Lexmark Office Equipment & Supplies
My HP Deskjet printer at work is saying it has a paper jam but there is no paper actually jammed. How do I clear the notice so I may start printing again??
If the machine indicates a jam, there may be a tiny piece of paper in the machine somewhere between where it goes in or comes out. Or a jam sensor arm might have broken off. Take a real good look using a bright flashlight. Good Luck !
Jan 08, 2011 | Office Equipment & Supplies
How do you put the adding paper into the machine? My machine is a EL-1197iv
Never insert paper roll if torn. Doing so will cause paper to jam.
Always cut leading edge with scissors first.
1) Insert the leading edge of the paper roll into the opening. (Fig. 1)
2) Turn the power on and feed the paper by pressing . (Fig. 2)
3) Insert the paper roll to the paper holder. (Fig. 3)
DO NOT PULL PAPER BACKWARDS AS THIS MAY CAUSE
DAMAGE TO PRINTING MECHANISM.
Jan 03, 2011 | Sharp EL-1197PIII Calculator
Paper is jammed inside printer - part of paper torn off trying r
In the back of the machine, there is a door/hatch that you can remove. That might help you.
May 24, 2010 | HP DeskJet F4280 All In One Printer InkJet
Paper goes scew whiff when trying to print. Says there is a paper jam but none visible.
Smaller torn bits of paper may still be in the printer. Unplug the power, open the back access panel. Look for torn or jammed paper. Also check the ADF (auto document feeder) for a jam.
When you try it again, Dell recommends that you fan your paper. Fanning the paper helps break apart the bonds left by improperly cut paper which leaves the edges of the sheets interlocked.
Dec 05, 2009 | Dell 962 Photo All-In-One InkJet Printer
Paper jam. I am getting an error message to open door, clear carriage jam, and then press enter. I did that but proble persists. There is no paper in the machine, no jam.
It is most likely that there is still a piece of paper in the machine. Was the paper you removed from the machine torn? Are you certain you have all the pieces?
Most HP printers have an access panel on the back that you can open to retrieve paper jams. Many people don't know to open that panel and look for paper. Try that.
Jul 17, 2009 | HP PSC 2175 All-In-One InkJet Printer
RE: Pixma MX300. I just recently started having a no start on the printer side from my computer. The LCD says there is a paper jam, but upon inspection I found no such jam. The machine still insists that...
it ia very muchpossible that If the paper tears and a piece remains inside the machine, you get this error, turn the machine off, open the Scanning Unit (Printer Cover) and remove it. Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step (1), all print jobs in queue are canceled. Reprint if necessary.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, If you attempt to open your machine, be extremely careful when you take the scanner portion off, as the ribbon cables are rather sensitive and you really don't want to break them!! If you do decide to take apart your machine, you do so at your own risk!!
after opening the paper feed sensor in the 'Engaged' position, which tells the printer that a piece of paper is being fed through the machine. Upon further investigation, you will find a black wire tie that was blocking the sensor from going back to the OK position. It actually kind-of made sense, as when you got this machine, it was held inside the box by an insane number of these things, and one could very well have fallen inside, or fell in from the factory. After removing the wire and putting the whole thing back together, you need to power it on and low and behold, no more paper jam was being reported!
I have posted some pictures of the part in question, for those who might not know where/what to look for. I apologize if the clarity isn't the greatest, but you should at least be able to figure out from here where to find the problem on your machine (if it's the same sensor giving the trouble!). If you found this posting helpful, feel free to leave comments. Thanks!
07ddd1f.jpg Here you can see the paper sensor behind the roller wheel. You do have to take off the cover to completely see it, unfortunately
Here is a much closer image showing the paper level. When the machine is loaded with paper, the lever will be pulled forward, allowing the laser between the two pillars to shine though the whole way. Be sure to clear as much dirt and debris from here as possible. My cable tie was wrapped up around this lever, holding it forward all the time (so it thought that it was loaded with paper).
Here is a distance shot of the printer in it's torn-apart stages, showing you where the sensor is in relation to the rear of the printer. The large black piece sticking up is actually the flat piece of the printers insides; There are several fiddle wires holding this in place, I chose not to disconnect it, but with enough playing around you could probably remove it if you had to.
Aug 12, 2008 | Office Equipment & Supplies
Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Feb 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Pixma mp810 paper jam?
Go inside the unit, the jam is most likely to be a very small torn shred of paper, near the carriage roller or similar. Us ea torch if the room is not bright enough, this helps fing it.
Feb 13, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
50 people viewed this question
Clive
Clive
old marine
old marine
