Question about Whirlpool Refrigerators
Whirlpool fridge fresh flow makes a tremendous growl every time i open the door and every 20 mins with door closed. I replaced the missing filter (it was empty), but it's still screaming at me. HELP
SOURCE:
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
tborn6
  • 700 Answers
SOURCE: whirlpool side by side fridge ice maker quit working
its soundss like iuts stuck in defrost mode.
Posted on Apr 03, 2009
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
SOURCE: every 20 mins or so the fride--a11 yr old
is it shutting off when it makes that clunking noise? if so, thats the compressor making the noise. the motor inside the shell casing, which is suspended on four springs, is banging agasint the shell casing because one of those springs has stretched or broken. You need to replace compressor. if its been happening for a while, i would start looking for a new model. if its more recent, and not very loud, you haver more time, but in either case, it could just cease up at any time. to hgave your compressor replaced, and unless your an HVAC tech you should most assuredly NOT do it yourself, its quite expensive, at or near the cost of buying a new one.
Posted on Feb 26, 2010
Testimonial: "Thanks. It made me cancel my appt. for service that was going to cost me $86.00--even if he did nothing. I'll put the money towards a new fridge."
SOURCE: Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Posted on Mar 15, 2010
My whirlpool fridge starting make a loud noise on and off
You could have a ice block fan, take all your food out and keep it cold, then unplug the unit with doors open and let it defrosts 3-4 hours if this solves the issue you should do this process once every 2 months. If not is time for special service
Aug 19, 2016 | Whirlpool Refrigerators
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
My fridge/freezer is having problems dispensing cold water. It works well when the fridge door is open, but struggles and makes load banging noises when the door is closed.
That would be a clear sign that the tubing is folding when the door is shut. When the door is opened you should also not be able to use the dispenser functions without pressing the light switch in. I believe on yours the water line comes in the left hand door at bottom near the hinge. Can you find the model number so I can try to provide a visual presentation? Look around the fresh food door and near floor for the model number of your Whirlpool. Thanks, Sea Breeze
Oct 20, 2009 | Whirlpool Refrigerators
Fridg is not working right
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment. Something is restricting that air flow which causes your fresh food compartment to stay warm.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Hope this was helpful. Good Luck.
Aug 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator won"t cooled.
Find the model number and let me know some things that are happening and not happening and I will help you solve this.Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser won't shut off nor will the ice dispenser motor
Apr 01, 2009 | Electrolux Refrigerators
How to reset water filter indicator on whirlpool american fridge freezer
Resetting your "change filter" light:
  • Press the light switch (the one that the refrigerator door presses every time you close the door) 5 times within 10 seconds. OR
  • If the fridge has a filter button, press and hold it for 5-10 seconds.
Mar 09, 2009 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
