Question about Sony Video Game Consoles & Games
Sony kdl-45ex521 TV recognizes bell hd receiver for a few minutes then picture goes out and message on screen says, "no signal. Check external input." Can you help?
I've tried replacing HDMI cables and using different devices such as the xbox but same thing. Any suggestions?
3 Suggested Answers
SOURCE:
SOURCE: KDL-40V5100 TV HDMI Issue
I have the same problem did you ever find a solution
Posted on Apr 01, 2010
  • 4 Answers
SOURCE: Hello My, just bought Sony KDL
I have one of these. It is probably set up for some other program like the HDMI or Input 1 through 5.
You can press your INPUT button, then scroll to the TV function, which should show up on the top.
Posted on Jan 09, 2011
Why when I use the inbuilt projector of the Sony Camcorder HDR-PJ240E with an external device,the projected screen becomes plain blue after a few minutes?
This maybe due to the external device not receiving signal to keep the display on the screen or a cable that isn't quite right. Many HD cables can cause this issue due to a security feature built into it to prevent streaming copies which helps prevent piracy. If you are using say an HDMI cable, try a different one.
Nov 26, 2014 | Sony HDR-PJ240E/B Full HD Handycam...
I have a Sony Bravia KDL-22BX300. When I turn it on, within the first few minutes I get this loud blast of static-y noise & the picture goes all snowy. It'll last approximately 10 seconds, then the...
This problems it is the tv Tuner signal board itself it is dying,just not dead yet.This problems the tv Tuner signal board is slowly dying,when it is completely dead.Ur tv will have only LED power light indication.No broadcasting tv signal at all.The tv Tuner signal board,that the board,where the incomming broadcasting signal cable plug into it.U can wait until it completely dead or like to change it now.Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Jan 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a sony bravia kdl-52v5100 the picture looks like a regular tv, I have digital hd signal (direct tv and ps3) they are connected thru hdmi 1.4 but I not happy with the image, how can I get a full...
Hi...
The manual will give you step-by-step help in getting the correct video mode for HD signals
If you dont have a manual , check the Sony Consumer website and download one
Oct 12, 2010 | Sony KDL52V5100 52 in. LCD HDTV
I have a Sony Bravia KDL-40EX400. Every morning I have to reboot my cable box to get my cable signal. I get the "Unsupported Signal" message and no picture if I don't. I have seen other posts about this...
All symptoms show that cable box is cause of problem, not sure that its internale circuit problem (signal processing in cable box) or its getting distorted signal from cable company.
TV sounds good because it works fine with blu ray player that is HD signal as well.
Change cable box just to confirm it.
I hope this tv would be under warranty so ask nearest Sony service to update its firmware under warranty cover that might fix the issue.
Thanks.
Jul 05, 2010 | Televison & Video
TV Cable card slot loses signal immediately after channel find
may be tv main board problem ..if you can switch  cable HD  box you can  save money
Jan 08, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How to improve picture quality?
are you using an hd source ? hd cable box, satelitte receiver or antenna with the digital channels programmed in. regular tv channels will not look as good as the picture you saw in the store when you bought it. they all use only high definition signals.
Dec 14, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
After power on my Sony bravia it goes to Digital
While tv in On position, select AV1, push power button to standy, then unplug tv for 5 minuts. check the out come.
Aug 03, 2008 | Sony BRAVIA KDL-46V3000 Television
Sony BRAVIA KDL-40S2000 40 in changing from HD to digital channels
40X2000, both PS3 and DVD player are using a HDMI input and both flicker and loose signal fully, have to turn TV of then back on to get signal back. Sony say they have never heard this problem and replaced board. NOTHING fixed, still same problem.
Mar 09, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Video Game Consoles & Games Logo
27 people viewed this question
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
