Question about Mamiya Cameras
Where I can repair Mamyia 6 or maybe purchase parts for it ? Thanks in advance Alex
Hi, I dropped my Mamiya 6 and broken foldable lens holder. I took it to the local photo repair service and they told me that some small leverage is broken .
  • 26,869 Answers
SOURCE:
spotatohead
  • 95 Answers
SOURCE: Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Posted on Dec 16, 2008
mail541
  • 58 Answers
Solutions here....
http://www.apug.org/forums/forum51/16253-mamiya-rb67-lens-stuck.html
Posted on Jan 22, 2009
  • 1861 Answers
SOURCE: Plugs for Camry 2000 4 cyl.
The plugs that are supposed to be in a 2000 4 cyl Camry are :
PK20TR11 Toyota P/N 90919-01194
The K16TR11 plugs fit a variety of models.
They are found in the following units:
98/99 Corolla
95/97 Paseo
95/98 T-100 V-6
95-04 Tacoma V-6
00/04 Tundra V-6
There is no question that your dealer installed the wrong plugs.
I would really appreciate a FixYa rating for the information that I have provided you. Thnaks in advance.
Posted on Jan 26, 2009
SOURCE: JBL 410 headphones broken
The same happened to me. JBL says that repair services are not available for this product according to their website. Their suggestion is to buy a new pair!!!!!. What a shame. JBL products are quite good but the post service is ****.
Posted on Jul 13, 2009
  • 14 Answers
SOURCE: fauly aperture ring on mamiya/sekor 135mm f2.8 m42 lens
Does the aperture work when you turn the ring and push the aperture pin on the mount in? The lens should close down to the set aperture when you do this. If it does, then atleast the lens is useable.
What is missing is the detent for the click stops. This is a spring loaded ball bearing that 'clicks' into notches inside the ring. If this is broken or missing, finding a spring the right size might be a challenge, the ball bearing less so. To remove the ring and base, unscrew 3 screws coinciding with the 3 notches in the back plate, visible when you set the ring to f8. the back should lift off easily. don't lose the screws. The ball bearing, if it is still there, should protrude from a small hole in the lens barrel in line with the f stop index mark on the lens. Good luck.
P.S. The above is based on how my 200mm is designed so I'm making some assumptions that the 135mm is put together much the same.
Posted on Oct 27, 2009
Mamiya RB67 Pro S: film counter does not advance, but the film does advance purchase another back same problem. Is there a switch that I'm missing??
If the problem is on the magazine's counter and if the spacing of frames is correct then the counter dial is loose. two screws on the outside front of the top of magazine, two screws in the film chamber hold the top cover. remove leather cover on winding lever loosen screw and remove. you can then remove the complete top housing to expose the counter mechanism.
Oct 30, 2013 | Mamiya Rb67 Pro S Medium Format Camera-...
I bought a second hand Mamiya 645 Af but as soon as I load a film it shows a error message ERR 01 .... what is that ?
From the manual:
"If the error display is not canceled when the shutter release button is pressed again, insert the Dark slide, half-press the shutter release button while pressing the roll film holder's manual film advance button to wind up the film, then contact your nearest Mamiya agent or service center."
If you need a manual, you can download one from
http://butkus.org/chinon/mamiya/mamiya_645af/mamiya_645af.htm
Aug 04, 2011 | Mamiya 645AF Medium Format Camera
I have a mamiya 645 pro camera I can't remove the old film spool from the camera ? JoAnn
Squeeze the two handles on either side of the "120" or "220" label on the film holder to pull it out, then the spool is easily removed.
Jun 15, 2009 | Mamiya 645 Pro 80mm F2.8 N/L Lens
Taking apart and putting back the freznel screen of a Mamyia 220
Those are spacers for equal plane for all corners.
Without the service manual, then you are up the river without ...
Just try to put spacer(s) on one side more than the other and close it up. Now look thru the viewfinder with lenses attached and check for sharpness.
If you're doing lots of cloe-up or macro, then those spacers are needed. If you can't correct problem, just shoot at F5.6 or higher.
You will have to remove or add spacer(s) by using T & E methods.
eltroman
atdlee@netzero.com
Jan 04, 2009 | Mamiya Photography
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Mamyia rz 67 pro II
I've got the same problem :-( Help would be appreciated.
Apr 03, 2008 | Mamiya Photography
Onkyo DX C220
The little drive belt that operates the CD lift mechanism is likely busted. I just started looking for belts now.
Dec 29, 2007 | Onkyo DX-C390 6-Disc CD Changer
Cameras Logo
185 people viewed this question
Top Mamiya Cameras Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Mamiya Camera Expert? Answer questions, earn points and help others
