Question about John Deere Garden
How do i adjust front wheel toe on a john deere l108
    Habit-Forming:
    New Friend:
  • 47 Answers
The maintains on a John Deere 108 including the front wheel toe is very similar to toeing a vehicle. Measuring the two front wheels back and front to find out how far off the wheels are, when toeing the wheels in there is an adjustment bolt at the back of the wheel. After adjusting the toe---measure the two wheels again, if still off repeat adjustment until they are pretty close to the same measurement
Posted on May 11, 2019
3 Suggested Answers
SOURCE:
  • 6468 Answers
SOURCE: ADJUST TOE OUT ON stx46 JOHN DEER
some are fix rods others have a lock nut and threads to adjust
Posted on May 15, 2012
  • 226 Answers
SOURCE: john deere 145 toe in adjustment
Adjust by measuring between the wheels {metal rim} at the 9 and 3 o'clock positions. I.e, halfway point on the rim at the front and rear. You can measure between the tire, but it is more difficult to get a good, repeatable measurement. If it were an MTD, you could adjust the toe by bending the tie rod/ drag link.
tom
Posted on Dec 19, 2012
Undefinedright front tire out of line,l-130 riding lawn momer .right front
If the tie rod end has been changed, you will need to adjust the toe in by dropping the tie rod end from its connection to arm. Not the steering rod. Tighten or loosen the tie rod end on the steering rod until there is a slight toe in. Re install the tie rod end into the steering rod. If there is too much toe in, the wheels will spread when in reverse and steering is impossible. It may take several attempts to set the toe in properly. When proper adjustment is met, steering will be easier or as it should be.
Oct 16, 2014 | John Deere Garden
John deere L108.drives for about 2 minutes mowing and stops.leave for about 15 mins and will go again.puffs of smoke when put under load
John:
The puffs of smoke when you put the machine under a load make me think that your carburetor is loading up and needs to be adjusted. Adjust the fuel/air adjustment screws on the carb until it runs properly.
Jan 20, 2013 | John Deere Garden
John deere 145 toe in adjustment
tom
Dec 19, 2012 | John Deere 22HP VTwin 48" Riding Mower
May 14, 2012 | Garden
How do you adjust the steering toe on a L130 lawn mower?
The L130 off of the show room floor does not have adjustable drak link / tie rods.
One of the 300 hour inspections is to inspect the steering pivot bushings. You jack up the front from the center and check for play of the pivot bushings by teetering the tie at the 6 and 12 oclock positions. If you get a lot of movement the bushings are bad. If the bushings are ok (I doubt they are) then you can also add adjustable tie rods
1 GY20492 ROD, RH DRAGLINK ASSY. ADJUSTABLE
1 GY20491 ROD, LH DRAGLINK ASSY, ADJUSTABLE
http://cgi.ebay.com/John-Deere-Tie-Rod-Drag-Link-L110-l120-L130-L-Series-/280669312038
They are more expensive at JD ($66.00)
Just note the pivot bushings do NOT show up on any JD diagram but they do exist. Check with JD parts. They most likely know the PN from memory.
http://jdpc.deere.com/pimages/MP29/MP29762________UN16SEP02.gif
Thanks for choosing FixYa,
Kelly
Jul 27, 2011 | John Deere 22HP VTwin 48" Riding Mower
Fuel leak at fuel tank. L108 John Deere
Some of the older L-series had fuel lines come loose at the fitting just under fender deck to the left of the fuel cap.
Sep 03, 2009 | John Deere Garden
Have a John Deere L108 will run but stalls out when the mower deck is in gauged.
This sounds like the grassbox switch.Get someone to press down on the box at the back and see if it works, if it will you will have to adjust the switch.
May 15, 2009 | Garden
Garden Logo
Top John Deere Garden Experts
Dave
Joseph Mueller
Joseph Mueller
john h
Are you a John Deere Garden Expert? Answer questions, earn points and help others
