Question about Veo Stingray
Logitech webcam I am using msn and can see the webcam. On trying to communicate with a nother person no streaming is taking place
  • Anonymous Feb 27, 2008
    no tengo el cd de instalacion
  • CFRITZGES May 24, 2008
    I HAVE A XP COMPUTER AND A VEO STINGRAY S/N 301VB1AX0
    HOW DO I GET IT TO WORK?
    President:
  • 8,637 Answers
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 14, 2009
My logitech webcam won't work in msn messenger....in messenger when i try to make a video call...it says I need to buy or install a webcam? what's the deal? heeeelp
Hi Marilyn,
Have you installed the Logitech Quickcam program? If you did then open the application and select the instant messenger(i.e. MSN, SKype, Yahoo) that you will be using the camera.
If you have note yet installed the Logitech Quickcam application then I suggest you disconnect the webcam and run the software first.
Oct 28, 2010 | Logitech QuickCam Communicate STX Personal...
I have logitech webcam logitech mic but cannot get the mic to work through windows live webcam works
Typical audio set up
Laptop x webcam/mic x Vista x MSN Messenger
If you have an earlier OS, you may have to access your hardware from the Control Panel.
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO MSN MESSENGER
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Jan 10, 2010 | Logitech QuickCam Communicate STX Personal...
How do i communicate with other people wi the use of the web cam
You can use one of many services, MSN messenger, Google Video Chat, Skype, these services are usually free.
The other person you wish to talk to should also use the same software to make thing easier.
Good luck
-Carlos:
Jan 08, 2010 | Logitech Webcam
My web cam won't work with msn
press ctrl+shift+esc to open task manager and check your processes that are open its going to be one of those thats stopping you
Jul 30, 2009 | Logitech QuickCam Communicate STX Personal...
Logitech e1000 notbook doesnt connect to others msns
if you are using a proxy server ...you have to fix the messenger on that server too ( and otherwise if its setted on a proxy and you are using a broadband.... high speed ......)...also ...try to upgrade the windows live messenger to the last update ...if you are using the one it was installed with the windows..its not gonna work until update ..
Apr 07, 2009 | Logitech QuickCam Communicate STX Personal...
Webcam
yes you need to use yahoo or msn and then chat with that person and if you want to see them on cam you invite them to view webcam.
Dec 06, 2007 | Logitech QuickCam Pro 5000 Webcam
Sound
i can see them but cant hear them
Jun 06, 2007 | Logitech QuickCam Communicate STX Personal...
Logitech quickcam communicate stx
Check the camera settings are not too high 320x480 or similair should be enough. Have you installed Windows Messenger live, the new MSN and tried it with that? If your'e problem persists try this problem page. http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=534&p_created=1087233145&p_sid=tDSxcPki&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PWRmbHQmcF9ncmlkc29ydD0mcF9yb3dfY250PTQyMiZwX3Byb2RzPSZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aWxsIG5vdCBpbnN0YWxs&p_li=&p_topview=1
Mar 04, 2007 | Logitech QuickCam Communicate STX Personal...
Veo Stingray Logo
23 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Sulkhan Abesadze
Sulkhan Abesadze
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
