try checking if there are plastic locks that prevents from opening the case of your laptop. It may somehow be located on the side or the bottom of the laptop.
Attention: Dont force it to open it may break the lock..
compaq laptop will boot fine sometimes and then other times when I turn it on there is just a blank...
(More)
compaq laptop will boot fine sometimes and then other times when I turn it on there is just a blank screen.
acer laptop will not update networki adapter. was having trouble running windows xp and had to...
(More)
ACER Laptop will not update networki adapter. Was having trouble running Windows xp and had to reinstall it. now I need a disk to update my adapter but I bought this used and I do not have the disk. 802.11a/b/g wireless LAN
can my toshiba laptop run on a 175watt power inverter in truck? the toshiba is satallite l305-s5974,...
(More)
can my toshiba laptop run on a 175watt power inverter in truck? the toshiba is satallite l305-s5974, and inverter is a roadpro 175watt/140watt constant with overload/overheat protection built in? the power ac pack puter came with is part#pa3715u-1aca modle #pa-1750-24, its input is 100-240v, output is 19v, 3.95amps . i bought it and was gonna run on inverter in truck but was told by radio shack i would burn up my computer unless i buy theres for 100.00 dollars.? what do u say? dont want to kill my computer running it on wrong item.
