PC Laptops
Problem for PC Laptops
Generic problem for all PC Laptops
I have hp pavilion dv4 laptop . The wif...
By lizabelloo on Aug 07, 2009
I have hp pavilion dv4 laptop , with vista windows.The problem is when i switch my laptop into battery ( without charging) after sometime the wifi is disabled !
also i can see my device manager is freezing .
After some trials i can switch the wifi again to enabled
any solution to this?
Solution #1
posted on Aug 07, 2009
Not Rated)
adnanbhatti
Rank: Guru  Computer Hardware  Expert
Rating: 85%, 292 votes
Your laptop goes into power save mode once the power suppply is disconnected. WIFI consumes a large amount of power so the system shuts it down to save power. You can disable it by going into control panel and power options. There you can change the power settings to allow wifi to run when using battery.
Was this helpful?
Yes
No
Solution #2
Not Rated)
mccafes
Rank: Wiz  Computer Hardware  Expert
Rating: 86%, 20 votes
Hi I think I no the solution. In some laptops when you switch to the battery it disables the wi-fi after a period of time - this is entering power saving mode.
(Do this while on the battery power)
Go into your power options in the control panel. There you will see power save, balanced and performance. which every plan you choose go to settings and you will see the wifi options.
As for your device manager freezing make sure you are up to date with all vista updates by tpying into the search box "windows updates". Also recently there was a service pack released for vista make sure that is installed as there are some hot fixes!!
Was this helpful?
Yes
No
Solution #3
Not Rated)
Dissolu
Rating: 92%, 165 votes
At the time when laptop is charging, go to power settings and disable the battery (energy) saving option, as this option starts to switch off devices one by one to prolong the discharge time.
Was this helpful?
Yes
No
Popular Solutions for PC Laptops
Questions and Unsolved Problems for PC Laptops
Answer
No message.
Answer
the best site i have ever visited,,, thanks fixya guys
Answer
I tried two brand new LCD Screens and two inverters but lcd displays in four desktop sections even... (More)
Answer
keyboard is not working mouse pad is not working, when the mouse pad pointer pointed at any item it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptops Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
