Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hotpoint Washer Dryer Leak in left corner
Hi, I have a Hotpoint Washer/Dryer thats developed a leak in the left ,bottom, front corner of the unit. I've cleaned out the dispenser and had the top of the machine off to get a better view of dispenser and pipes, all look dry and fine. The door seal looks ok too, no obvious holes or splits.
Thanks in asvance for any help.
  • voodoo1 Nov 28, 2007
    I ahve the same problem, it only seems to be a small leak! But still a pain!
  • 249 Answers
Watch the drawer closely as it fills, on out side of machine it might be hard to see or else small hole in door seal also hard to find good luck luck close ire
Posted on Nov 28, 2007
Water leak in front left corner of unit. Rusty leveler near strainer.
Is the leak on the same side as the hinges? If yes I'm guessing someone overstressed the hinge when opening the door too widely or by leaning on the open door and the seal is just barely tight enough now. Crack the door open half an inch and eyeball the door gap from top to bottom on the open side to see if the door is unevenly hinged - you can use a ruler to help measure but you need to keep the door immobile while comparing top and bottom gap widths. Tape a hard wedge in place in the doorframe to help with that. Fix for that? Pressure on the door in the right direction to straighten the hinge mount.
Feb 25, 2014 | LG WM2688HWM TROMM SteamWasher
AC does not blow cold air.
Hello, all the refrigerant most likely leaked out. To fix a leak it might be a bit expensive, sometimes to repair a leak will cost more than to buy a new unit.
Jun 20, 2012 | Friedrich XQ10L10A Air Conditioner
Hi i have a leak under my hotpoint wdl540 the pipes are all clean and dry and the washing machine still works where would the water be coming from?
Could possibly be a little knick in the door seal or from the corner of the dispenser (the drawer in known to leak and the best remedy is to adjust the front feet so the unit is tipping back slightly, this allows gravity to help the flow of water in the drawer ). The valves could be leaking on the inner side if the machine, Really depends on whether it is a flood type leak or just a small puddle/drip. Run the machine pulled out, whilst stood on some newspaper, this should help trace the area of origin. Keep an eye out when it drains that your plumbing isn't blocked and so the drained water comes out of the standpipe instead of flowing away. Keep me posted or repost if you need further advice. All the best.
Oct 18, 2011 | Hotpoint Aquarius WD640 Front Load...
I have water leaking from the dispensing tray, only on the pre wash filling..any suggestions I have a hotpoint washer dryer wd64
Check the level of the machine, may be leaning slightly forward allowing water to leak on that one fill cycle. Lift the front a little by using the adjustable feet and see if it stops.
Feb 16, 2010 | Hotpoint Aquarius WD640 Front Load...
Water leaking out of bottom of machine
either tub has leak or bottom seal is bad. you may have to go in from behind washer. View here for more info and don't hesistate to ask more questions:
Oct 01, 2009 | Hotpoint Ultima WD72 Front Load...
Do i have a filter i should clean on my hotpoint wd440 washer dryer?I ask this as it has recently started to leak from somewhere at the bottom front left corner and someone suggested the filter may be...
most washer do not have a filter per sec and if leaking the front panel should be able to come off by lifting the top assy then once removed you will be able better to see where the water is leaking from if come from above the transmission it would req an overhaul...
Aug 19, 2009 | Hotpoint Washing Machines
My kenmore 417.94812301 stacked washer / dryer slow leak
I am leaning toward the pump leaking. Physical inspection will tell. Sears website will show exploded view of parts. Start under Parts direct tab. Good luck. link to sears.
Jun 30, 2009 | Kenmore 98702 Stacked Washer/Dryer
Filter on WT960
hi, in the uk the filter is behind a flap on the bottom/front of the machine, be careful as when you undo it some water will leak out, hope this helps
Feb 09, 2009 | Hotpoint Aquarius WD63 Front Load...
bad pump..take some news paper and slide in from bottom you will notice that the drip is coming from the left side more,,..if you can get behind unit theres 2 green clips on the right and the left remove these,,if you cant get behind remove front panel ..and remove from front...slide lid forward than remove lid switch connection right front corner,,now the tops off...remove the 2 screws holding washer front your in ,,to put back reverse...att'' always unplug unit first
Sep 30, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washers leaking
Oct 21, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
213 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
