1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears •Release the power button but *continue holding the home button*, for another 30 seconds. Step Thanks
Try to remove memory card and battery and wait for 15 minutes to reset the phone. Check you memory card for errrors. now insert batttery and switch on if camera works fine then inserrt scanned memory card into the phone.
If there are still issues then you might have to checck for hardware issues of the camera or fault in the software which must be reinstalled.
Hi you have got bad cells in the battery and this is preventing it from holding a full charge so even though you leave it on charge it will never last long, all you need to do is get a new battery and your phone will be back to normal
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
First Option: mostly nokia chargers doesn't make problems... just try the following.. connect ur mobile with a system (usb cable)... found out whether it is charging or not... if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)... if it charged with usb cable buy a new charger Please change Phone Bettery and check the charging IF Charging Problem not Solved So
Secend Option: Your Phone charging IC Fault So Please change charging IC And charging Problem will Solved Quickly
I've just had this problem today and couldn't find any advice either. My battery was low and 'sent messages' box was fairly full. I charged it up, emptied the sent box, switched phone off and removed battery. I took sim out and gave it a wipe before replacing it. Switched it back on and it's working again! Not very technical, I know but it seems to have worked! It's driven me mad all day! Hope this helps????!
put the charger on it and leave it for an hour, it may need a good charge to even get switched on. If that doesn't do it then you will most likely have to but a new battery. If that is the case, I would first take it to the store where you bought it and ask them to test the battery and charging system for u, a free service.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Hi this problem is going to ba faulty battery i had the same problem after replacing the battery it was fine. The problem was a couple of bad cells inside the battery but what your supposed to do to prolong the life of the battery is to let it go totally flat once a month i mean totally flat so it wont even light phone up then do full charge this keeps the cells good in the battery so remember to do this often should keep the battery lasting ages let me know if you need further assistance
Thanks very much. Have tried replacing the battery 4 times already, still the same problem... :-(
Thanks again.
