Question about Sony Cameras
I want to ask, can the Sony NP-FH50 battery & Sony charger with the BC-VH1 model number for Sony A230 be used on the Sony A200 ??????.
SOURCE:
  • 473 Answers
SOURCE: Can a lithium ion battery be overcharged?
Here's a small FAQ I found: 1) My lithium ion battery is the SONY NP-FP70 Battery Pack. Does the fact that the battery is called a battery pack mean that it has built in circuitry to prevent an overcharge? No. I write with some authority since I've dissected too many and there is no such circuit in the battery. From a system perspective it doesn't belong there. 2) Is there any way of knowing if my SONY BC-TRP charger has the circuitry for preventing an overcharge? You'll have to ask, but the key clues are: a. The documention tells you to not leave it plugged in overnight. b. The battery gets too hot and melts the plastic. 3) If I charge my battery in my camcorder (SONY DCR-HC40), can I assume it has the built in circuitry to prevent an overcharge? a. One can't assume anything. b. But from what I read on that model, you plug it in and forget about it. To do that, it would have a proper charge circuit.
Posted on Sep 13, 2005
SOURCE: Battery charger light flash
Its pretty simple to fix. The lithium battery has just depolarized. Just buy a 9V battery.... put them end to end... the 9V and the lithium and touch the metal parts of them. hold for 20 seconds... if it doesn't work, lick the 9V to conduct the electricity better.. hold for 20 seconds and put directly on the charger... I just did this, and it is charging as we speak! good luck!
Posted on Feb 18, 2009
  • 100 Answers
SOURCE: sony aa charger model BC-CS2A
it might be it might just be a fulty charger
Posted on Jun 04, 2009
  • 241 Answers
SOURCE: Can the BC-NH01 battery charger also charge AAA
In reality, yes. The AAA batteries are to short for the charger, so some fiddling is required. I'd recommend you buy a suitable multicharger instead.
Posted on Apr 13, 2010
  • 177 Answers
SOURCE: WHEN PLUG IN BC-45W CHARGER
Scrape any dirt from the contats of both the battery and the charger.
Check the wires and plug for any loose connection.
If it charges normally apart from the light, then the fault is only with the light.
Posted on Dec 12, 2010
I have battery charger model no.BC-CS2A during charging after 7 hours indicator light is off that what is this indication.and after indicator light off charging process do continue or...
When the light is off, its mean your batteries already full so charging process stopped automatically.
After usage and the battery empty again, you can recharge them and you'll get the light is ON again.
If this helpful, RATE please !
Jan 20, 2011 | Sony Portable Battery Charger for NP-BG1...
Tip
Sony np-f330 battery...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 19, 2010 | Computers & Internet
I have used my Sony Handycam DCR-SR40 and the battery went dead. I then charged the battery several times and still won't turn on. I even attach the camcorder to the Sony base and connect it to the...
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sep 06, 2010 | Sony Handycam DCR-SR40 Camcorder
Want to upgrade to 6.20
Here is a direct link to the PSP System Update v6.31.
CLICK HERE!
It has detailed instructions on how to update your PSP.
Hope that helps, give me thumbs up please!
Aug 23, 2010 | Sony PlayStation Portable (PSP) Console
When I turn on the handycam dcr-dvd108 it gives me a blue screen that says cannot use this battery in the camcorder. It is a brand new battery that we bought because it gave me the same message with the...
This camera problem sounds as if the battery is not sitting in it's contacts quite right, check below to see if you have the right one, I think they are mostly grey to fit your model.
Battery Type: Li-ion
Voltage: 7.4V
Capacity: 1500mAh
Color: Dark Grey
Dimension: 44.95 x 31.72 x 43.37 mm
Product Type:Replacement Battery (Brand New)
Replace Part Numbers:
NP-FH30, NP-FH40, NP-FH50, NP-FH60, NP-FH70
May 22, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
DSV-V1 no power, doesn't react on battery or batterycharger
You may still have a battery fault, and the only way you'll find out is to buy or borrow an external charger such as the Sony BC-VC10. Buying a new battery won't solve it as they're supplied uncharged.
If you live in the UK and can post the battery to me I'll try to recharge it for you and will post it back afterwards.
BTW: Is your battery a genuine Sony InfoLITHIUM C, model number NP-FC11?
Jun 28, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
How to charge a EFORCE FH50 Compatible Battery
Its appealing simple; Probably you will be accepting sony handcam charger accepting a cable thats declared to fit into ur camcorder and again allegation the battery. For charging the EFORCE FH50 battery, you just allegation to admit that the of the aforementioned cable anon into the battery(DC-IN slot) and bung ur charger into the bank socket. It commonly takes 135 mins to absolutely allegation the battery. Once answerable the LED at tthe DC-IN aperture will about-face off. (During charging its yellow)3_27_2012_9_39_48_am.gif
Apr 05, 2009 | Sony Handycam HDR-CX12 Flash Media...
HANDYCAM USE
Go to any Sony dealer ask for NP-33 battery pack for your CAM
Cheers
Dec 08, 2008 | Sony Handycam CCD-TRV416 8mm Analog...
Cameras Logo
23 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
