Question about Kenwood Car Audio & Video
How do I connect the Kenwood KRC-2001 to my speakers and power up? Do you know the wire color codes?
    Master:
  • 231 Answers
This should be very easy. Kindly take a photo of the harness. Post here and I will help you. Or talk to me at ask@electronics.co.ke
Posted on May 08, 2019
SOURCE:
  • 437 Answers
SOURCE: need wiring color code for power &speaker
red -Acc power
yellow -12 memory power
black -ground
blue -amplifier remote
blue/white -power antenna
SPEAKERS
white left front +
white/black left front -
grey right front +
grey/black right front -
green left rear +
green/black left rear
purple right rear +
purple/black right rear -
Posted on Aug 25, 2009
  • 145 Answers
SOURCE: LOOKING FOR COLOR OF WIRE TAKING POWER IN TO THE
red is the 12 volt power line. yellow is the memory line(constant 12 volts) . small red wire is the switchable 12 volt line that only has 12 volts when keys in ignition
Posted on Nov 17, 2009
saailer
  • 1871 Answers
SOURCE: I HAVE A KENWOOD KRC-2007 CAR STEREO AND DON'T
Hello! Front Right; + = Grey... - = Grey/White
Front Left= + = White... - = White/Black
You are correct...Perhaps you need the vehicle's colors?
If so send a comment with year, make and model...
Guru.....saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Posted on Feb 18, 2010
Testimonial: "THERE IS A GREY AND GREY/BLACK AND WHITE AND WHITE/BLACK BUT NO GREY/WHITE. AFTER HOOKING IT ALL UP I FIND THE STEREO DOESN'T WORK ANYWAY. THANKS AGAI"
  • 44 Answers
SOURCE: i have a kenwood krc-2001 and im wondering what and i need help
I'LL MAKE THIS VERY EASY FOR YOU, IT WILL ONLY COST YOU ABOUT $25 MAYBE LESS. JUST GET A WIRE HARNESS FOR YOUR CAR, PEPBOYS OR ANY AUTO STORE, JUST TELL THEM THE YEAR AND THE MAKE OF YOUR CAR AND YOU WILL BE SET, THE WIRING IS COLOR CODED, MAKE SURE THE HARNESS CONNECTS TO YOUR FACTORY HARNESS.
Posted on Mar 15, 2010
skayalgomas
  • 88 Answers
SOURCE: Wiring color codes for kenwood krc-12
Posted on Jun 02, 2010
Im tring to match up this radio wireing to a chrysler lhs i need to know what colors go to what the kenwood krc 235 wire to the chrylser car wireing (red to pink blue to orange like that)
I recommend you purchase a wiring harness specific for that vehicle instead of trying to hardwire it. You run the risk of frying your entire electrical system if you do. Wiring harnesses are about $7-$20. Plus, it takes the guesswork out of wiring. Visit www.crutchfield.com if you are looking for one.
Aug 14, 2011 | Car Audio & Video
How do i connect a kenwood krc 394 radio cassette,+ve battery, eth, and speaker connections.
Head unit color code:
12V-Yellow
12V switched-Red
Ground-Black
Illumination or Dimmer-Orange/Orange w/white stripe
Blue-Power Antenna
Blue wwhite stripe-Amp turn on
Whites-FL speaker
Greys-FR speaker
Greens-RL speaker
Purples-RR speaker
(Black stripes negative)
If you have a female harness to connect to the veicle side you will pretty much color match. The only exception is that you may only have an amp turn on wire but only a power antenna on the vehicle. In this case you would connect blue w/white stripe wire from radio harness to the blue antenna wire on the vehicle side.
If you are doing a hardwire (factory plug has been cut off) you can obtain a wiring code for your vehicle at www.the12volt.com for most vehicles.
Jun 06, 2010 | Kenwood KRC-394 Cassette Player
Wiring diagram for Kenwood KRC-2007?
red wire is key source black wire is ground yellow wire is menory 12 v source is that is on all time rest are speaker wires make sure u put the full color wires as ur pos side then the wires with a blk line thur is neg side
May 15, 2010 | Kenwood KRC-2007 Cassette Player
I have a kenwood krc-2001 and im wondering what and i need help
Mar 15, 2010 | Kenwood Car Audio & Video
I HAVE A KENWOOD KRC-2007 CAR STEREO AND DON'T KNOW WHICH COLORED WIRE GOES TO THE LEFT AND RIGHT FRONT SPEAKERS, I THOUGHT IT WAS WHITE/WHITE BLACK AND GREY/GREY BLACK.
Guru.....saailer
Feb 17, 2010 | Vehicle Parts & Accessories
I have an old Kenwood KRC 2001 cassette radio which I would like to fit to a car just bought by my daughter but it has no electric/speaker connector. Can anyone please tell me what output/input each of the...
red is battery. some have two red wires, but they are both battery(12 volts). it is a switchable 12 volts which means it comes on when you start car. yellow is a constant 12 volts. it is for memory. blue is for power antenna(ive never used it. i keep blue wire disconnected) then you have the set of colored wires like green and gray stripe. those are speaker wires. match it with its other color coded wire. example.....brown with yellow stripe wire goes with the brown wire to connect speaker. enjoy
Nov 21, 2009 | iLO XM-MP3-CD Car Stereo
I have a kenwood krc-557l and dont know what wires are what...
Red is "Key on Pwr"
Yellow is "Constant Hot" always powered
Black is "Ground"
Blue is "Pwr antenna or amplifier remote turn on"
This is tapping my memory a little, however, I believe stripe is positive on Kenwood and solid is negative. The easiest way to test spkr wiring is to connect your pwr,gnd,etc. then make sure all other wires are individually taped barring one. Use any speaker, turn on the radio, connect one wire to pos & one to neg on spkr, look at the cone of the speaker, if it pops out, you have the correct wiring "in phase" if it's incorrect, the spkr will appear to pop "in". That's "out of phase" reverse your wiring.
Hope that helps
May 17, 2009 | Car Audio & Video
Need wiring schematic for Kenwwod KRC-2000 cassette receiver
Yellow : Battery - should have a 1A inline fuse - (memory)
Red : Ignition - should have a 5A inline fuse - (power)
Black : Ground (chassis)
Light Blue : Power antenna
Green : Left Front Speaker
Orange : Right Front Speaker
Blue : Left Rear Speaker
Red : Right Rear Speaker
Gray : Common ground for all speakers
Hope this helps.
Nov 12, 2008 | Kenwood Audio Players & Recorders
Kenwood krc 479r
If there was no spark and wires hooked up wrong in the first place, your player should work if you find the PWR lead and the Remote lead and ground. Then speaker wires +) and (-
Sep 25, 2007 | Kenwood KRC-479R Cassette Player
Car Audio & Video Logo
26 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
