Question about Canon imageRUNNER 2000 Copier
SYSTEM ERROR E100
After i replace te drum cilinder of my Cannon ir1600 the display shows:system error E100. How can I solve this problem by my self?
Thank you in advance.
Vali
Hey
How can I solve this error code(IR1600) on my canon copier by myself?
Posted on Jun 21, 2008
  • 57 Answers
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Posted on Nov 28, 2007
If you want the permanent solution about error e100 contact me at
www.bigro.it
Posted on Oct 25, 2012
  • 86 Answers
I know what your problem is phone 07764303923
Posted on Feb 14, 2008
Hello experts i gat a problem ma cannon iR1022iF shows error SYSTEM ERROR E100 how can i get in touch with this problem coz it took long enough without solved
This error code is dealing with the laser not being detected by its sensor. Check to see if the tab on the drum hasn't been bent or broken off, this pushes the laser shield out of the way so the laser can write to the drum. Lasers don't usually go out.
Apr 22, 2017 | Cannon Office Equipment & Supplies
I Just replaced the toner in my CANON IR1600 PHOTOCOPIER and now have the Error code E100. I put the old one back in to see if it was different but it still said E100. How can I fix this? Thanks
Hi carolyn ,
I am a professional canon service eng . My Name Is D K Kumar . e100 is not related to toner at all . it is the indication that the develper unit has not been detected . remove the left side cover . you will be able to see the top of the develpoer unit. On the left top portion of the developer unit u can see a white coloured accuvator . it is a small white plastic piece ..whhen the side door is closed te white piece should get pressed or should move forward . if the moving action is not happening then the m/c will give u E100 error. in your case the reasons /problem could be :
!) The spring connected to the white plastic accuvator is missing or spring action is not happening.
2) the white accuvator it self is broken or missing.
3) the plastic stick /piece which protudes from the side door and pushes the accuvator is broken.
4)lastly you have not closed the side door properly or not closed at all.
Carolyn if u r able to understand my above tips thn u can do it your self , if not call a your local canon enginer.
best of luck God Bless u
P.S. Carolyn if my solutions have helped u then i request u to kindly reply to me at my enail id: narkumar81@rediffmail.com
Apr 10, 2011 | Canon Office Equipment & Supplies
I have a fax machine Cannon Super g3 laser class 710 showing a system error E100, what does this mean?
toner cartridge problem! check the actuator from the drum cartridge! maybe broken.....
May 07, 2010 | Office Equipment & Supplies
How do i fixed system error e100 on cannon
How many copies do you have? If over then 55000 change the drum unit.
But it can also be the laser trouble.
Mar 15, 2010 | Canon PC1061 Copier
Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
Jul 15, 2009 | Canon iR 2016i Black and White Copier
System Error E100
Most likely, the tab on the rear side of drum unit has broken off. Thus causing the Lazer Shutter not to open. There are 3 or 4 other possibilities other than replacing the drum unit.
Jun 02, 2009 | Canon iR 2020i Laser Printer
Sir,My IR1600 dosnt fuction or now dosenot start to work
Hi, do you have an error message like E100 ? Please be specific.
Mar 22, 2009 | Canon imageRUNNER 1600 Laser Printer
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon imageRUNNER 2000 Copier Logo
4,481 people viewed this question
old marine
old marine
