Question about Kenmore Refrigerators
My refrigerator Kenmore two years old, the lights are not working. I bough a new one but only works one day.
    Habit-Forming:
  • 138 Answers
Ana; Possible you do have a bad Live neutral or grounding AC plug on wall. Your new one quit in one day , it is possible when your ac line is sparking or bad connection. The main controller or power board or main controller this faulty. Your old one possible has a power issue. You need to ask electrician first to check your ac wall where the ref is connected.
Posted on May 07, 2019
SOURCE:
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 1462 Answers
SOURCE: Rust spots appearing on front of doors of kitchen (indoor) Kenmore refrigerator.
paint ain't perfect!
rust on a 15yr old appliance is normal
Posted on Dec 01, 2008
SOURCE: Kenmore Elite Refrigerator 59676264700 loud clicking noises
check for bad relay
Posted on Jul 29, 2009
  • 93 Answers
SOURCE: Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Posted on Sep 13, 2009
Kenmore Coldspot 106 Refrigerator
It's 12 years old it's gone ,they don't last forever ! Compressor !
Aug 18, 2015 | Refrigerators
Hi my refrigerator is new, but the machine is not work, is not cool. The compresor doesnt work. I connect to the wall but never frezze
Call who you bough it from and tell them and they will check it out. If it is under a year old, it is under warranty. Be sure to turn the controls to the mid settings and wait 20 minutes (it could be in a defrost cycle). If nothing happens after 20 minutes, make the call.
Jan 03, 2010 | LG Refrigerators
Freezer door lost power, will not dispense ice or water, light does not work Kenmore/10 years old /side by side
Check the door switch.
If the door switch is not working the light will not work and the ice or water will not work.
John
Sep 28, 2009 | Kenmore 57029 Side by Side Refrigerator
We are very discouraged with out kenmore appliances. They didn't seem to last as long as we'd like. Our refrigerator is only 8 years old and it's had problems from the beginning. We are now replacing a...
Hello. I do not work for Sears but I do work on lots of appliances. Do not put 500 into a computer board.
All appliances these days are designed to last about 7 years. If yours last longer, consider yourself lucky.
The good news is a new fridge and a new freezer will use much less electricity and will save you money within a couple of years.
Jul 07, 2009 | Refrigerators
Kenmore elite bottom freezer refrigerator...water won't work
I turned up the temperature in the freezer and the refrigerator. The next day the water was flowing.
Thanks for your time.
Sherry Piper
Jan 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dec 01, 2008 | Refrigerators
No water or ice from older kenmore side by side
You must pull fridge out the water valve is in the bottom back. Sounds like the valve is stuck open. You can Google your model# to find appliance parts to order new valve.
Nov 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Dec 05, 2007 | Refrigerators
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
27 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
