Question about Kenmore Refrigerators
The Kenmore refrigerator light is not working. I bought a new one but only works one day. The refrigerator only has two years new.
SOURCE:
VANMAN69
  • 23 Answers
SOURCE: freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Posted on Jun 29, 2007
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 146 Answers
SOURCE: My kenmore refrigerator kept running.
It's not the relay, Your problem is either the evaporator motor or the condensor motor. Does it sound like a bird chirping or a high pitch grinding noise? If so move your refer out and get in back of it then pull your back panel at the bottom of the refer. and check and see if your fan is running. Whenever the condensor fan motor slows down or stops it causes the compressor to overheat causing it to come on and go off whenever the compressor gets too hot. If it is the evap. motor open the freezer door and check and see if you have a frost build up on the back panel. If so your evap. motor is bad and you will need to change it. Whenever your evap. motor slows or stops it causes your evaporator to ice up and freeze causing your refer to run all the time because the air flow is restricted. I hope this helps.
Posted on Dec 18, 2007
eagle338
  • 4889 Answers
SOURCE: kenmore refrigerator problem
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube. Do this and all will be back to normal..
Regards,
Sai.
Posted on Jun 13, 2008
I have a Kenmore refrigerator, model #25365812508, purchased in October of 2010. It just stopped working. There is no power. The interior lights aren't on, the ice dispenser lights aren't on. ...
sounds like it's stuffed. Best git yerself down to walmart and see if they have them on new year sales. And git the 10 year extended warranty for $50 so your covered if the new one breaks down.
Jan 06, 2018 | Kenmore Refrigerators
Moved refrigerator to new house, power was off for a few days.The last time the power was off for a bit, a few years ago, it would not cool.Repair man came over took a handfull of snow and placed it around...
no!! ? never hear of this kind of vodo treatment :) what is your model#? and what is it doing now? is the compresor working? is the fan in the back runing?
Dec 30, 2009 | Kenmore Refrigerators
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer works but cooler isn't cold
Try unscrewing the light, bulb mine did the same thing I couldnt figure it out. It turned out to be the light switch! Everything is fine now.
Aug 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dec 05, 2007 | Refrigerators
Kenmore Trio Elite 596.75529400
Has anyone got you a solution? I think I have the same problem with mine!
KSheridan
Oct 27, 2007 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Our refrigerator stopped working, compressor not kicking on.
Sounds like the problem that I had. The repairman replaced the relay switch, which is usually located behind the refrigerator, bottom left.
Aug 20, 2007 | Kenmore 64802 Top Freezer Refrigerator
Refrigerators Logo
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
