Televison & Video Logo
j
jimmie nelson Posted on May 07, 2019
How can i program a universal remote to my tv if it wont turn on with the power button
5 Related Answers
Anonymous
  • 207 Answers
  • Posted on Apr 10, 2008
SOURCE: programing philip universal remote to my tv
You can find the instructions here. Just follow the step by step instructions to properly select model of your Phillips remote. http://www.urc.philips.com/
Anonymous
  • 8 Answers
  • Posted on May 25, 2008
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Anonymous
  • 45 Answers
  • Posted on Jul 25, 2008
SOURCE: RCA universal remote RCU703SP wont program Magnavox TV
cheap universals dont hold as many codes, the best universal remote is the all for one range with the best being the comeleon
Anonymous
  • 11896 Answers
  • Posted on Jan 17, 2009
SOURCE: TV wont turn on with remote or the power button
ONE: The protection circuit has taken over the power managment of the set. When you unplug it for a couple of hours or so and plug it back in it will start up because the circuits have all been reset (unplugging the power cord is a reset operation.)
TWO: The protection circuit goes into action whenever it detects an excessive amount of current being drawn from one of the 10 sections of the tv circuitry.
THREE: When it won't turn on it is because the protection circuit has captured the ON function and holds the power relay OFF until it is reset.
FOUR: So, the problem area could be any one of the 10 or so sections of the tv. The most common of which is the high voltage section because it uses the greatest amount of power. If so, this could be very expensive.
FIVE: On the other hand, it could be one of the other sections and a small part such as a resistor or capacitor shorting down. In which case the cost of repair may be only a few dollars.
SIX: However, you will need a tv tech to come to the home and diagnose the set because we cannot tell where the failure is without a hands-on diagnosis by one who knows how to test the circuit sections.
SEVEN: Usually a shop will send out a tech who will do a quick check and tell you what is wrong with the set and how much the repair cost is going to be. A house call such as this will cost from $40 to $80 depending on the distance and the price they set. I suggest you call a few shops and get their best response before deciding which one to employ.
Let me know if you will need further assistance
Anonymous
  • Posted on Jul 01, 2009
SOURCE: cant get universal remote to work with broksonic tv
Code 0115 worked for me on the Phillips PM335 remote FINALLY!!!!!!!!!!
2answers
How to program an LG universal remote to my onn tv
Order a factory remote on ebay, they're only a few bucks.
Can my remote control RC00136P pair with my Vizio dvd player?
  1. Turn on the TV or device you want to use with the universal remote.
  2. Press and release the TV button on the RCA Universal Remote. (The red light on the remote will begin to flash)
  3. Now simultaneously press and hold the Power and TV buttons on the RCA Universal Remote. The on/off button will be illuminated and then turn off. After a moment, the button will relight, it should remain on.
  4. Aim the RCA Universal Remote at the TV. Release both the on/off button and the TV button on the RCA Universal Remote simultaneously.
  5. Next, press and release the Play button on the RCA remote. The TV or component should turn off after about five seconds. If there is no response, continue to press the Play button until the TV or other device you are programming turns off.
  6. Now press the reverse button. If the TV or device does not turn back on, continue to hit the reverse button until it does.
  7. Press the stop button once the TV has turned back on, this will save the programming settings.
  8. Your RCA universal remote is now ready to use
Model LED32B30RQ need 4 digit code to program universal remote. RCA TV
The 4-digit code to program a universal remote to work with a RCA LED32B30RQ TV model is likely to be one of the following:
11447 11758 11442
To program the universal remote to work with the RCA LED32B30RQ TV:
  1. Turn on the TV
  2. Press and hold the "Setup" button on the universal remote until the "TV" button blinks twice.
  3. Press the "TV" button on the remote.
  4. Enter the 4-digit code for your TV using the number buttons on the remote.
  5. Press the "Power" button on the remote. The TV should turn off.
  6. Press the "Setup" button again to lock in the code.
If the TV does not turn off after entering the code, please try the other codes listed above. If none of the codes work, you may need to refer to the universal remote manual or contact the manufacturer for further assistance.
Note: The method to program the universal remote may vary depending on the remote brand and model
How do I program my F-2100 universal TV remote
Programming an F-2100 universal TV remote can vary depending on the specific model, but in general, the process will involve the following steps:
  1. Locate the Code List: The F-2100 universal remote comes with a code list that lists the codes for different TV brands. This code list can be found in the manual that came with the remote or can be downloaded from the manufacturer's website.
  2. Turn on the TV: Make sure the TV you want to program the remote for is turned on.
  3. Press and hold the TV button: Press and hold the TV button on the F-2100 universal remote until the light at the top of the remote turns on.
  4. Enter the code: Using the number buttons on the remote, enter the code for your TV brand from the code list. For example, if your TV brand is LG, you would enter the code "10178"
  5. Test the remote: Once you have entered the code, press the power button on the remote. If the TV turns off, the remote is now programmed to control your TV. If the TV does not turn off, repeat the process, trying different codes from the code list until you find the one that works.
  6. Repeat the process for other devices: If you want to program the remote for other devices such as a cable box or a DVD player, you will need to repeat the process, using the appropriate button for the device you want to program.
It's important to consult the manual or contact the manufacturer for detailed instructions of your specific model
Proscan Tv/dvd magnovox universal remote codes
Here are some Magnavox universal remote codes you can try to use with your Proscan TV/DVD combo:
  • 11963
  • 11603
  • 12746
  • 12260
  • 10587
  • 12070
  • 11990
  • 10178
  • 10030
To program the Magnavox universal remote to control your Proscan TV/DVD combo, follow these steps:
  1. Turn on your TV/DVD combo and point the Magnavox universal remote at it.
  2. Press and hold the "Code Search" button on the remote until the LED light on the remote turns on and stays on.
  3. Press the "TV" button on the remote to program the remote to control your TV.
  4. Enter one of the codes listed above using the number buttons on the remote. The LED light on the remote should turn off if the code is accepted.
  5. Test the remote by pressing the "Power" button to turn on the TV/DVD combo. If it works, try other buttons on the remote to control your TV/DVD combo.
  6. If the first code you entered doesn't work, repeat steps 2 to 5 with another code until you find the correct one.
If you are still having trouble programming your remote, consult the user manual or contact the manufacturer for assistance.
How do I program this RCA nightclub universal remote for my Samsung smart TV
First understand that you need a little patience with this remote, it's a little slow, it may take a few seconds in between pushing buttons for it to react to your TV.
1)
-Turn on TV manually first.
we're going to try and get the remote paired to your particular tv
2)
-Facing RCA universal remote towards TV, press and hold both the POWER and TV buttons on the remote at the same time.. until the RCA universal remote POWER button lights up and is constantly on.
-Then press the PLAY button on RCA universal remote
(POWER button on remote should be blinking after pressing PLAY -- what the remote is doing is trying to program your TV with a list of codes. if your TV does not automatically shut off after a minute, press the PLAY button again. your TV should shut off. wait a few seconds before trying to press PLAY button again if you need to try again.)
3)
Assuming remote turned off TV. Now let's try to get the remote to turn on your TV
On the remote at top right is a REVERSE button, press that. You should see the POWER button on the remote blink once in response to you doing that.
Watch for the power on light on your TV.. your TV may take a few seconds to power on..
Wait a couple seconds. if your TV has not turned back on, press the REVERSE button again. the POWER button should blink once again in response
If your TV did not turn on. You may have to repeat pushing the REVERSE button waiting a couple seconds for the remote to try turning on your TV. For some people this can take several times, if not a dozen times. Just be sure to be patient and wait a couple seconds in between pressing the REVERSE button again. (what the RCA universal remote is doing is going through a list of codes trying to find the right model to pair to)
4)
Assuming the remote finally turned on your TV.. We are almost done. We programmed the remote to turn off the TV and turn on the TV. now we want to press the STOP button on the RCA universal remote to lock in those codes into the remote. After pressing the STOP button the light on the remote POWER button should turn off.
5)
We are done. You should be able to change the channels and raise and lower the volume of your TV.
1helpful
2answers
I have a jvc 32inch tv and the on and off power button is missing i cant turn my tv wont turn on or off i bought a universal remote and my tv is still not coming on
Program the universal remote following the instructions manual for that model TV. Usually holding the power and TV button until the TV power light comes on. Or, try the combination codes for that model TV.
5helpful
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
NEED SONY CODES FOR PHILLIPS REMOTE
Universal Remote Control Simple Setup
* Point it at a TV set and press the Mute/Power button. (Mute button if TV is already on, or Power button if the TV hasnt already been turned on)
* Keep pointing it at the TV until the TV turns on or muted, most TVs respond in about 5 seconds, the most is up to 20 seconds. (Other universal television remote you find in stores take minutes to program and enter long confusing codes)
* Once the TV is muted or turns on, simply let go of button and you have total control. You can use the remote as if you had the original remote, and responds instantly. ENJOY YOUR FREEDOM of choices with our remote!
Most remote controls require minutes of programming a universal remote code into each television while you read the confusing instruction manual.
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
