Question about JNC Computers SSF-35 (512 MB) MP3 Player
Not working The MP3 player is charged but it will not turn on. When I plug it into the PC it registers and indicates "starting" but nothing after that. I can see the files on the device through windows explorer but I cannot do anything else?What am I to do next?
2 Suggested Answers
  • 108 Answers
SOURCE: can't save new files onto my mp3 player
Most of the Mp3 players do have physical switch to write protect, if you can locate it try to switch off write protect option if not after connecting device check the drive is read only if thats the case anticking read only.
Posted on Dec 06, 2007
  • 19 Answers
SOURCE: Memory not avalible on my mp3
it might be that u have saved the files in a different place without realising or u have replicated the songs.
Posted on Dec 08, 2008
0 characters
1 Points
Mp4 player 4gb
According to an earlier fixya post by spoil5, it's a common problem with Transcend mp3 players usually because of a defective battery and/or the operating firmware.
Transcend MP 860 Review
His tips:
  • Keep the battery charged, don't let it go flat
  • Try the trick with the volume control
  • Replace the battery
Here's his temporary fix to make charging work:
  • Turn on player.
  • In main menu press and hold the rocker button in up position.
  • You should see volume adjustment indicator.
  • While volume indicator is increasing, plug USB cable connected to turned on power supply.
Important: the volume must keep changing at the moment of plugging the cable (cannot be stopped at max position). If necessary set volume to 0 first and then start from 2.
Check out this solution to the Transcend sonic 610 MP3 Player problem...
Feb 01, 2014 | Transcend MP3 & Digital Media Players
My m3904-a wont turn on i charged it ,on plug and computer, and nothing tryed the reset many times and nothing so what do i do
I had the same problem and I found a solution to make it work but do this ONLY as a last resort because this ERASES all of your files and you will have to download them again. Plug your mp3 into the computer. If your mp3 doesn't register on the computer then hold down the start button on the mp3 and hit the RESET button on the back of the mp3 with a toothpick. Once it registers on the computer, hit the start button on the computer, click on Computer, then go to the drive that is associated with your mp3. Right click on that drive. Click on Restore Device Defaults. I am not a pro but this worked for me. Good luck!
Jan 30, 2011 | RCA Lyra RD1072 MP3 Player
How do I charge my daughters amt mp3 hello kitty clip on. when I plug it into my computer do I turn the player on to charge or keep it off. she was kind enough to lose the directions.
G'Day To charge your AMT mp3 player you must first plug it into your PC USB port using the supplied cable. Next turn on the player using the sliding switch on its side.The indicator shows the battery is charging, but it is not. To make it charge you have to turn the player off. To do this, hold down the "play" button until you get the "Bye-Bye" message. The screen will go black and the battery will now charge. Do not use the slide swich to turn off!...woozie. Australia
Jan 18, 2010 | MP3 & Digital Media Players
All of a sudden it will not turn on....nothing...when plugged into the say fully charged....but if you disconnect..and try to turn it on.....nothing happens..
If you can turn your player on while being plugged to your PC/Laptop or USB charger, then your internal Lion battery is most likely gone past its useful life (some 500 charges or 18 months usage) and may need replacing. Most MP3 player may show 'fully charged' when plugged in either when the battery is truly fully charge or defective battery is no longer taking a charge: e.g. minimum or no current flow situation.
Dec 20, 2009 | RCA M4204 MP3 Player
Creative zen stone plus wont turn on
the battery is dead use a car charger it worked on my creative zen stone plus and ipod touch. the car should charge it
Jun 10, 2009 | Creative Labs Zen Stone Plus MP3 Player
Zune wont charge
unplug the zune. hold the back button and hold the up button until the zune restarts. wait until it turns back on. open the zune program. then plug in your zune. it should work.
Dec 31, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Opal MP3 playe
yea i try everything and nothing have happen
Aug 03, 2008 | RCA OPAL M4001 MP3 Player
MP3 Player no power
get a pin and press the little reset button in the back
May 10, 2008 | Coby MP-C7085 MP3 Player
Wont start
Could be corrupt firmware.
Install and run Philips Device Manager from the product CD.
Select the Repair / Restore option.
Press and hold [VOL+] on the player whilst connecting to the PC, and follow the on-screen prompts.
Apr 01, 2008 | Philips SA5125/37 MP3 Player
Gigabeat Will Not Turn On - Battery Flashes Then Goes Dead
have you only been charging it with the usb cable?
try plugging it into a ac adaptor, (make sure the button is in the off position at the bottom)
and it should hopefully restart, then turn it to the on when it's loaded, and leave it plugged in till it's completely charged
that might work
Feb 26, 2008 | Toshiba gigabeat S MP3 Player
JNC Computers SSF-35 (512 MB) MP3 Player Logo
20 people viewed this question
Top JNC Computers MP3 & Digital Media Players Experts
Are you a JNC Computers MP3 and Digital Media Player Expert? Answer questions, earn points and help others
