Canon PIXMA  iP1800 Printer
Problem for Canon PIXMA iP1800 Printer
How to remove ink in th full ink absorber?
By masterart on Aug 07, 2009
what is the best solution for the pop-up that the ink absorber is almost full for canon printer ip1880?
Best Solution
posted on Aug 19, 2009
Very Helpful)
bulletcradle
Rank: Apprentice
Rating: 97%, 8 votes
waste ink absorber error message can sometimes be solved by resetting the printer itself. i havent yet tried in ip1880 but in ip1200, th e resetting method is this: (it might also work on other models)
1. unplug the power cord and the data cable(printer to pc) 2. while press-holding the (printer) power button plug the power cable (do not release printer power button until step 3) 3. press 'resumet' ( the button below the power button of the printer) button twice... 4. release the power button 5. connect the usb cable of the printer to the pc... - a new canon printer shall be found in the list of printers. use it as default printer
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #2
posted on Aug 07, 2009
Helpful)
rajonline
Rank: Wiz  Canon Expert
Rating: 85%, 112 votes
Hi ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Don't forget to vote if this helps ... Cheers :)
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for Canon PIXMA iP1800 Printer
Questions and Unsolved Problems for Canon PIXMA iP1800 Printer
Do you recommend Canon PIXMA iP1800 Printer?
Answer
Answer
When I try to print, the paper will not go through even though I can hear the roller rolling. It's a... (More)
Answer
IP 1800 always worked then received error message: "printer offline" Help plz
Answer
absorber pad is full show all the time, wont print
Answer
i have a Canon iP1800 printer and when i attempt to print a pdf file it says "unable to start... (More)
Answer
I have a problem with my canon pixma IP1800 printer which shows error indicating paper jam and could... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
