Question about Kyocera FS-3900DN Laser Printer
Kyocera fs 3900dn printer
Hi my priter has got the following eror code on it:0150:0014523. can you please tell me what is wrong?
  • triumphadler May 11, 2010
    I have the same problem with my Triumph Adler 4035 Printer, which is same as Kyocera 3900DN. Please send me the Firmware-Update with instructions (if possible in german language).
    Nice Greetings meister@nyc.com
I have a problem in same printer it shows 0150:0004597
Please suggest what to do?
Posted on Dec 13, 2007
  • Subhendu Das Dec 13, 2007
    Please send me the solution to this e-mail id, d.subhendu@gmail.com
    Thanks in advance
  • Kyocera Master
  • 1,113 Answers
It needs a firmware update, very common, it would most likely be under warranty, if not post email so I can give you the firmware update required and I will instruct you on how to upload it to your quality printer.
Posted on Nov 27, 2007
I have Kyocera FS-3900DN , it shows on the display error code (call service 6030:1022274) thanks
This problem is caused by a poor contact in the fuser connector terminals.
Check both sides of the connection (in the printer and fuser unit) In most cases we will find small pieces of paper inside printer connector causing poor contact between printer and fuser unit connector.
Hope i was of any help. If i was, please rate me.
Thank you.
PcSimples
Mar 14, 2011 | Kyocera FS-3900DN Laser Printer
Hi, I have a problem with my Kyocera FS-3900DN. The display shows the fault 7410:0043899. How can I fix it? Thanks
Will just reflashing the firmware fix this?
I have replaced the EEPROM (as per my post near the top) on a few of these, so that the printer will come to ready and then flashed the EEPROM via parallel port with upto firmware.
skyp techbelkin
Dec 19, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Kyocera fs-3900dn showing 7410:0024216 error code what do I do
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Apr 15, 2010 | Kyocera FS-3900DN Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Error code 7410: 0026060
7410 error
most likely you need to push the drum back till you hear click (drum at the left side at the prt)
Jul 10, 2008 | Kyocera FS-3900DN Laser Printer
Triumph-Adler 4035 Firmware
latest firmware for FS-3900DN:
system: 2F9_3000010.004 checksum:5204 version:010.004
engine: S2F9_1000011001 checksum:f7bf version: 011.001
I don't think the problem is in the firmware ...
May 02, 2008 | Kyocera FS-3900DN Laser Printer
Service code
This is a laser problem. The polygon motor probably got jammed usually it needs to be cleaned and oiled or the motor has ceased.
Mar 10, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Laser Printer Logo
873 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
