Question about Compaq Presario M2000 Notebook
Compaq Presario M2000 PC
When i swicth on power come & power off after 3 or 2 seconds. No start the computer. when ac plaged in computer just showing bettery light.
  • jonee Nov 28, 2007
    when i swicth on power come & power off after 3 or 2 seconds. No start the computer. when ac plaged in computer just showing bettery chirging light.
    Problem Solver:
  • 9 Answers
Hi Jonee
There is no reset button on this model so I would suggest, removing the ac adapter and battery form the computer and hold down the power button for at least a min. From there reattach the AC ONLY, then try to power the unit on. If it turns on great wait for it to get to windows then slip the battery in. If it doesn't even attempt to power on, lets look at the Ac power adapter. Does it have a light on it? Is it warm to the touch? It very could be that the ac adapter may have died and the system's battery doesn't have enough power left to run the computer. If this scenario happens you may want ot call HP or take the computer to a local tech where they can test the adapter for you and determine if it is working. The last thing to check is the power pin in the notebook. IS it very loose when plugging in the adapter? If it is, that would indicate a physical problem that won't be resolved unless a tech looks at it. I hope this help.
Posted on Nov 30, 2007
Compaq Presario M2000 stopped turning on
If there is no power going to the laptop then disconnect battery and hold the reset button in for 30 seconds, then try it again. Sometimes the memory can be damaged which can cause the laptop not to boot..?
Feb 08, 2013 | Compaq Presario M2000 Notebook
Do compaq presario m2000 laptops have sata ports
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Jan 05, 2013 | Compaq Presario M2000 Notebook
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
May 12, 2012 | Compaq Presario M2000 Notebook
Repair manual for compaq presario M2000
Free Service Manual,
Go down to the Compaq Presario heading. (Sixth line down)
Scroll across, and click on M2000.
This is a PDF file. It may take as long as 30 seconds before the first page comes up.
It may also take additional time for the file to fully download.
(Suggestion: Save it to your computer. Burn a copy off to CD disk. Run the disk to see if it's good, then delete it off of your computer to save harddrive space)
Plus;
http://www.insidemylaptop.com/how-to-remove-inverter-and-replace-lcd-screen-in-compaq-presario-m2000-laptop/
For additional questions post in a Comment.
Regards,
joecoolvette
Oct 14, 2011 | Computers & Internet
Turn on a s/h presario m2000 and it asks for a password of which i dont know what do i do`
try pressing esc. two times.
Or type admin for username or admin for password. Or try password for password.
Jul 04, 2009 | Compaq Presario M2000 Notebook
Battery won't charge
This is true, you will not be able to charge the battery without the correct charger. For mostly all laptops, when the charger is not maintaining a charge, it is time for a new one. However, it does not have to be the manufacturer's adapter, but I recommend purchasing the battery made for the Compaq Presario M2000 Notebook.
NextTag.com has decent deals on these adapters. http://www.nextag.com/ac-adapter-compaq-presario-m2000/search-html
I hope this helps. Please let me know if you have any other questions.
Thank You, Raph30
Jan 25, 2009 | Compaq Presario M2000 Notebook
Laptop will not start (compaq presario m2000)
Try removing the battery (which may be bad) and only have ac power connected.
RDO
Nov 17, 2008 | Compaq Presario M2000 Notebook
Computer will not turn on
This could indicate a bad battery, or bad memory chip. Try starting without the battery. If this doesn't work, then try takeing one or the other memory chips out. If the problem persists, then it may lie within the power management system on the motherboard.
Jun 26, 2008 | Compaq Presario M2000 Notebook
Presario M2000
i need intel presario m2000
May 08, 2008 | Compaq Presario M2000 Notebook
M2000 laptop
good!.
this means your computer is candidate for PRODUCT SAFETY CAPTURE. US gov requires all manufacturers to capture a product for safety reasons. call compaq and tell them that warranty is out, but computer has safety issues. its too hot to touch or had smoke come out of it. they should be able to give you a new computer. hehehehe! :)
Nov 27, 2007 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
206 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
