Question about Microwave Ovens
Timer switchesofafter1minuiteevenifyouputitonforlonger
  • Microwave Ovens Master
  • 9,098 Answers
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door located on the right side of the innards. The damper closes and opens depending on cooking mode. See the attached sample photo.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa:
You can order Sharp parts from Tritronics at
For other brands, you can usually find helpful exploded view diagrams and order parts by entering your full model number here:
Posted on Nov 28, 2007
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Nov 26, 2017 | GE Microwave Ovens
How can I set the timer and still use the oven to cook food?
Use kitchen timer not cooking timer, it's written on your oven timer pad. I did that before
Jul 05, 2015 | Maytag MMV4205 Microwave Oven
How to program clock & timer
on most: press clock, press numbers on keypad, press am/pm, press clock(on some press start). timer: press timer, press numbers, press timer.
Mar 11, 2015 | Microwave Ovens
Cook works microwave timer stuck
If by "manual timer" you are referring to a knob that you turn to set the cook time, then you may have a failure of the motor that turns the timing mechanism, or a lack of power to it.
May 10, 2014 | Microwave Ovens
Microwave timer doesnt ping off
this is probaly a clockwork timer you are talking about sounds like the contackts are stuck together in the timer pull knob off take screws out probally 2 disconnect wires from timer and replace they are not so expensive
Mar 28, 2013 | Microwave Ovens
Replacing the timer could solve the problem
Sep 25, 2012 | Microwave Ovens
INtermatic Model ST01 timer is to be used in a 3 way switch arrangement. The unit works in one switch position but fails to allow the light to turn on in the other switch position. Several other switches...
ST01C timer replaces one 3-way switch and the other 3-way switch remains.
The ST01C timer does not work exactly like a 3-way switch.
When the timer blue and red wires are connected together, they reverse whatever program is in effect.
When the timer is wired for single-pole, the red wire is capped off. When timer is wired for 3-way, the red wire is used to reverse the timer, thus causing the 3-way effect.
So if timer is ON, and red and blue wires are put together, the timer turns OFF.
That's why the remaining 3-way switch has to be rewired.
The remaining 3-way switch is rewired so it will connect and disconnect the red and blue wires, causing the timer to reverse program each time, and creating 3-way effect.
Other requirements of ST01C is that the black wire must connect to Hot wire, and the blue wire must always connect to Load. This means that you have to correctly pick which 3-way switch to replace, where the hot wire from breaker arrives.
Open following link for wiring diagram showing how to wire for 3-way:
All 3-way timers require rewiring second 3-way switch to create 3-way effect.
Jun 21, 2011 | Microwave Ovens
I don't have the Manuel to program a WESTEK TE22DHB timer. Can you locate one or tell me how to program it?
Many timers are sold under different brand names with different numbers.
For example Westek TE06WHB is same as Woods 59377
Sometimes different timers are packaged under same number, for example Utilitec TE06WHBL is shipped as the old Woods TD1300.
GE and Utilitec sell the same timer with different numbers.
Westinghouse and Stanley and Utilitec and Woods overlap.
I got manuals for some, and can sometimes cross reference if you describe the timer.
1) take a minute and add a comment with description of button layout with button names, or describe the dial and switches. Be as detailed as possible.
2) Look through timers on following links and see if your timer shows:
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Microwave Ovens
I have a Montgomery Ward "Household Microwave Oven, Model No. KSA-8200A, Manufactured April 1979." The analog timer has gone bad. How do I get a replacement timer?
Hi and welcome to FixYa. I am Kelly.
The Repair Clinic has parts for your Montgomery Wards Microwave but, they are NOT listed on the website. Call them with your model number and they can look it up: Make sure to tell them it is a mechanical clock timer.
  • 1-800-269-2609, 8 am to midnight ET, 7 days (Repair Clinic)
  • And...... if you can find a number on the actual timer assy other than the timer motor, there are still many of these mechanical timers out there deep in the parts supply shelves. I would bet your could still find this timer pretty close to home in a local Appliance repair shop.
    Just a note on older appliance parts (+25 years) .... sometimes the cost of replacement parts is far more than the unit cost new.
    Thanks for choosing FixYa.
    Oct 16, 2010 | Microwave Ovens
    Round soft key OXO Timer I need to change the clock time their model # is 1061978
    Operating functions:
    To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
    To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
    When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
    This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
    Sep 18, 2010 | Microwave Ovens
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
