Question about HP Compaq Presario v3000z Notebook
System not starting
My Laptop is not displaying anything on the screen eventhough the power indicator is turned on, also it turns on from off state automatically when ac adapter is connected, without displaying anything. what kind of problem is this? do i need to go for a hardware service?
Change the adapter and problem will be solved. trust me
Posted on Jun 23, 2008
May be due to RAM issue just remove and replace it.
Posted on Dec 07, 2007
  • 98 Answers
If possible, try to plug an external monitor to the laptop and see if it displays anything. That will indicate a video problem on your laptop.
Posted on Nov 27, 2007
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Black screen on start up
When you turn on the laptop and get a black screen, does it sound like the computer is still running(are any lights lit up etc) ? If so, then you possibly have a bad video display. I would highly recommend visiting a repair shop or contacting the manufacturer of our laptop for service repairs.
If the laptop is plugged up to any other display, or TV , unplug it and reboot.
If it does not sound/look like your laptop is actually turning on then you may have a power issue. You can try some of the following tips to see if it resolves your issue.
-Leave the laptop charging for 10 minutes then try and turn it on. It may not be charged up enough.
-Try a new power cable
-Try a new battery
-Try a different wall to charge the laptop.
Regards,
G33k
May 11, 2011 | Computers & Internet
Power is on but no signal output to the screen
The following applies to Acer Laptops. You did not specify the brand of laptop you had. If your laptop is not Acer, the specific keys mentioned may be different and you should adjust accordingly.
If the power indicator is lit but nothing appears on the screen - The computer's power management system automatically blanks the screen to save power. Press any key to turn the display on.
If pressing any key does not turn the display back on, check the following....
1. The brightness level might be too low. Press Fn and the right cursor key to increase brightness level
2. Display device might be set to an external monitor. Press Fn and F5 to toggle to the internal display
3. Backlight might be turned off. Press Fn and F6 to turn on the backlight.
4. If the Sleep indicator is lit, the computer is in Sleep mode. Press & release power button to resume.
Apr 04, 2011 | Computers & Internet
Hello, I had a problem with my Blue H1 laptop. I was re-installing my OS (window xp pro) and in the middle of a certain installation progress, the unit (Blue H1) has turned off entirely, and that the...
Dear Friend,
Your system has developed a hardware problem.Remove ac adapter and battery. Re install RAM SIMMs and try switching it on. If it switches on start OS re installation again.
Dec 28, 2010 | Computers & Internet
Not booting the system. the screen is not displaying anything
please check if you will see the Power On Self Test (POST), wherein this test is like a DOS prompt wherein the Specifications of Intel is specified. But if you don't see anything on the screen, try to remove the cables and battery after you turn off the laptop. Then press and hold the power button for 8 secs. Reinsert the cables and battery back to the laptop and turned on the laptop. If no display appeared, call Acer to repair your laptop. Motherboard problem is the main reason why...
Dec 22, 2010 | Acer Computers & Internet
No vidio display screen show nothing att all. The computer starts but I see nothing.
If you shine a flashlight at the screen and look it from an angle and can see your displayed screen faintly then the inverter board is bad and it needs to be replaced.
You can hook up an external monitor to your laptop in the meantime to use your system.
There is also the posibility your screen is no good. I'm thinking it will be the inverter board though.
Oct 17, 2010 | HP 530 Notebook PC
Battery on packard bell
Probably not. Try removing the battery from the unit and just power-up from your adapter connected to the mains. See if the problem persists. If so, you may have another issue.
What, if anything, do you see on the screen as it is booting? This may be an indication of the source of the problem.
Nov 19, 2009 | Packard Bell Easy One Silver 2120 Notebook
Doesn't want to start windows
In fact, that is the troublshooting technique when your computer does not boot up, insert the recovery disk and allow it to reload. The reload shoud be on the screen, otherwise you have a bad monitor and that's a different subject..Now why it happened is what we need to work on..did you do anthing like download programs are anything prior to this happending? Let me know who the re-install goes...since its refurbished it could be anything at this point.. let me know if you have any quesitonsl
Please rate this solution.
Mar 19, 2009 | Gateway MX6931 Refurbished Laptop - Intel...
Laptop was working fine, suddenly went totally black.
the display of ur laptop has got damaged....if u still have doubt that it might be some software problem try formatting ur system.. Or else u should go for a change of display screen
Feb 02, 2009 | Toshiba Satelite A135-S4467 Notebook
Denon AVR 2802
if the display did not lit and power indicator is flashing rapidly------you will have short circuit in speakers cables -----turn it off and remove short circuit cable-------or you have block in ventilation holes---------turn power off and leave it to cool down and remove anything block ventilation holes---and turn it on again after cooling---------another solution-------on screen display is set to off on system setup------turn it to on in system setup.
Aug 04, 2008 | Denon AVR-2802
HP Compaq Presario v3000z Notebook Logo
144 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
