Question about Lexmark X5470 All-In-One InkJet Printer
Keeps resetting Worked fine for over four months. Then tried to send a fax and half way during scan it started to go thru the start up routine. It just seems to carry on in a startup routine loop.I have tried disconnecting power and repowering but samer thing happens. I have disconnected network cable to PC but it still carries on????
    Champion:
  • 238 Answers
Hi, it looks like loose connection with the printer power connectors, or the mains plug , let me know
Posted on Dec 16, 2007
Lexmark X4270 won't send out a fax
If you have DSL. you need a filter on the line you are trying to fax through.
Mar 24, 2012 | Lexmark X4270 All-In-One InkJet Printer
Says unable to clean troubleshooting and routine maintenance chapter in user's guide ?????? I do not have a guide with this printer. Please advise... Thanks
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Aug 01, 2011 | Brother MFC-5440CN All-In-One InkJet...
Brother 165c clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide. clean unable 46
Error 46 on Brother printers The printer must be reset:
  • Press menu then*2864 within 2 seconds and press 80.
  • Keep pressing black/mono start button until screen displays 'purge count'.
  • Press 2783 to reset purge count.
  • Press stop/exit key
  • Press 99
  • The printer should return to normal
OR Resetting purge counter:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 12, 2011 | Brother DCP 165C Compact Color Inkjet...
Clean unable???
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
Mar 27, 2010 | Brother MFC 240C All-In-One InkJet Printer
Magic Jack quit transmitting, but receives on Brother 775 fax
wheneva i start ma magic jack it say connect to internet an put password its says correct but thn again its comes again connect to internert.... an password an email id... but pls help me in tis..??
Jan 07, 2010 | Lands Phones
Printer flashes "Clean Unable 46 - refer to troubleshooting and routine maintenance in User's Guide". I went to the user's guide and did all the maintenance/cleaning that was reccommended. Nothing cha
Try resetting the purge counter:
1) Enter machine maintenance mode (on MFC240C all fourphoto/copy/fax/scan lights flash in maintenance mode). Care is neededin maintenance mode, otherwise critical settings may be inadvertentlycorrupted.
FAX models with numerical keypads:Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if youfail to complete the correct key sequence within two seconds, press theStop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys.Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenancemode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the loginformation list to reach the purge counter. The purge counter is the25th item in the list.
Jun 02, 2009 | Brother MFC-3360C All-In-One InkJet...
Sharp Inkjet UX A 1000
I had the same problem and, like you, went to the internet to find a solution. One answer I found was to unplug the vax, wait one minute and then replug it. This didn't solve the problem for me. Out of desperation, I printed the fax "Help" pagea nd, lo and behold, after it printed my Sharp 510 Fax was back to normal.
Nov 04, 2008 | Sharp INKJET FAX UX-A1000
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Printer keeps restarting itself all the time, and does not print at all
Try downloading the latest firmware. Ti might sort it out for you.
Jan 30, 2007 | Brother MFC-5440 Printer
Canon MP830
When i am trying to fax a document it is saying that the memory is full. But when i go to the menu and to fax memory it is saying empty. How to solve this problem
Dec 19, 2006 | Canon PIXMA MP830 All-In-One InkJet...
Lexmark X5470 All-In-One InkJet Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
