Question about Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer not printing in WinXPP
I have installed the Epson TM-U220 Matrix Printer for use with a POS system running on WinXPP. Using the Prallel Printer Cable, I am able to establish communication with the printer on LPT1. I have even printed text data in a DOS environment and in WinXPP when I use the Generic Printer Driver. However, the Epson TM-U220 printer driver I downloaded from the net does not work - it shows "printer not available". When I send a print job, it remains in the queue but does not print. What do I do?
Richard Basiime
  • 1 more comment
  • Alibo Dec 15, 2007
    Yes I do have the same Problem.
  • jorge15 Jan 16, 2008
    en español...?
  • Anonymous Feb 09, 2008
    me podrian mandar los drivers de la mini printer tm-u220pa
    ya que no puedo echar andar el punto de venta por la epson
    Problem Solver:
  • 10 Answers
Hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
  • 98 Answers
Have you tried to print directly to the printer without spooling the print documents ? Try, on the Advanced tab for the Printer Properties, to select "Print directly to the printer" instead of "Spool..."
Posted on Nov 27, 2007
I have finally managed to print by downloading another driver meant for TM-U200. Obviously there must have been a problem of compatibility on the P3 PC and the TM-U220 printer. On the newer PCs (P4), the appropriate driver works fine.
Posted on Feb 03, 2008
Hello i got the same problem. i tried everything the whole day but to no avail...i guess it's on the computer and driver itself coz i used a working printer on the pc that i'm working the same problem occur. please help
Posted on Feb 02, 2008
Can i install two(2) EPSON TM-U220 printer on a terminal?
You can have as many printers as you want but each has to have a port defined. When you installed the driver, you must have defined both as one printer and now it's confused the system. Uninstall ALL printers and start again making sure each has a unique port.
Sep 13, 2014 | Epson Tm-u220 Pos Printer Serial Black
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
May 30, 2014 | Epson TM-U220 Matrix Printer
Download driver u220
I can't find driver to install la printer.
Jun 17, 2013 | Epson TM-U220PB Matrix Printer
PRINTER TM U220 on a Mac
Epson website should have them available to download
Jul 24, 2012 | Epson TM-U220 Matrix Printer
Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit site for more info.
Dec 24, 2011 | Epson TM-U220 Matrix Printer
I need driver for printer tm u220 for install for O.S windows server 2003
You can download the appropriate driver on the following webpage:
May 05, 2011 | Epson TM-U220 Matrix Printer
Every time I print it suddenly stops in the middle of printing and says "error".
hi there
the only one i could find is TM-U220 , which falls under the TM-U200 series, as stated in this link.. i i advise you to get in contact with Epson directly , as they are the only ones who can assist you with this issue..
I hope this serves you well
Nov 04, 2010 | Epson TM U210PD Matrix Label Printer
Can u give a download driver for pos printer
Oct 03, 2008 | Epson TM-U220 Matrix Printer
Tm-u220 problem.
it cann't print the test page
Apr 20, 2008 | Epson TM-U220 Matrix Printer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
Apr 03, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
5,880 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
