Question about Sony CDX-GT300 CD Player
Memory loss I have recently installed a Sony CDX-GT300 to my Peugeot 206. It works fine, however, every time I turn off the engine all the preset memory radio stations are lost. The CD that is in also goes back to the start of the disc. What's the problem? Thanks.
  • 1 more comment
  • Anonymous Dec 11, 2007
    i did what it said but i aint getting any power still to the head unit. so could it be a fuse or some thing.
  • russolo Apr 12, 2008
    the stereo in my car won't hold it's memory everytime i turn off the engine and start it again
  • Anonymous Mar 31, 2014
    when i turn off my ignition i loose all my programed radio stations and all the eq setings
  • 78 Answers
You need to remove the radio and swap the red wire for the yellow wire and vice versa, they have bullet connectors to allow you to do this, basically the permanent live and the ignition live are the wrong way round.
Posted on Nov 27, 2007
  • tom mcloughlin Dec 19, 2007
    If you are not getting a switched live at the back of the radio and the vehicle is newer than 2002 you may find that it is a can bus system so you need to find another switched live usually from the cigarette lighter supply and run a wire to the red lead on the radio
  • nobbyclarkgc Aug 29, 2010
    just as described mate i have a 1997 Audi V6 cabriolet with same drama been nigling me for ages till i seen this post , well done ,
I did what that says but still aint getting any power to the cd player when the car is off and still having memory loss. there's no power coming from hte 206 main wires to thecd player unless the car is on
Posted on Dec 11, 2007
Wiring diagram for cdx-gt450u
You may download the instruction and installation manuals from here. The wiring diagrams are on the first page of the installation manual.
Nov 29, 2012 | Sony CDXGT450U Car CDMP3 Player
How do I set the time on the Sony CDX-GT300? Car came with the radio but time needs to be set. and click on the user manual. Or
Press and hold the select button until setup display appears. Then press select button until clock-adj dspl. Use the volume control to adjust hour. Press dspl to change to minute or back to hour. Press select when done.
Jun 21, 2010 | Sony CDX-GT300 CD Player
Sony CDX-GT300 just cut out
By any chance, have you checked the main connector on the rear of the unit? I was having problems with the unit in my Harley cutting out and the front panel going dark and found that while the connector was still attached, the weight of the wire harness was tweaking it just enough to disconnect power. Try pulling, then reattaching the connector and if that fixes it, use zip-ties to take all of the weight off of the connector. Hope this helps.
Mar 11, 2009 | Sony CDX-GT300 CD Player
Sony cdx-gt300 AM radio malfunctioning
If no AM and everything else is ok , the unit needs to come ouit for repair...keep in mind that these are cheaper to replace than repair.
Memory loss since changing fuse!!!
The unit will have 2 fuses, or at least a second power supply that is generally connected to continuous power, best bet is straight from the +ve batt terminal. If this power supply has been disconnected or has a blown fuse, then you will also loose memory functions from you radio.
  1. Check first under the bonnet for a memory backup fuse holder that has generally less than 1 amp fuse,
  2. no luck, then about the rear of your fuse box for a fuse holder,
  3. or worst, behind the unit up under the dash. The wire from the back of the stereo on Sonys is generally the RED one for memory backup
restoring this power supply to your stereo will then allow for all your presets to be retained in memory
Good luck, happy to talk to you more about the problem, a "FixYa" rating will help my profile
Feb 14, 2008 | Sony CDX-GT300 CD Player
CDX-F7750S - Preset Stations Are Lost When I turn My car off.
check the wiring and see if you constant power is connected if its not connected you don t have no memory on the unit if its connected check constant power fuse on car
Nov 09, 2007 | Car Audio & Video
if it's only 10 months old send it back as it's still under warranty and won't cost you anything
Aug 14, 2007 | Sony CDX-GT300 CD Player
Sony CDX-GT300 CD Player Logo
1,310 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
