Question about HP Photosmart 935 Digital Camera
R927 wont turn on
I can not get the camera to turn on while in or out of the dock ?
  • Anonymous Dec 12, 2007
    Nothing happens when camera is turned on. I've changed batteries and charged batteries
  • shartwig79 Nov 28, 2008
    My camera will not turn on, at all. Not with ac adapter, not with batteries, not with anything.
    Genius:
  • 2,985 Answers
Remove battery and clean contact and then try.
Make sure the battery is fully charged or fresh
If still in trouble contact HP Support
Posted on Nov 28, 2007
Where can I buy the original dock station for my HP Photomart R927 digital camera?
You can go to the original online website to choose one which have a good after sale service .
Aug 27, 2013 | Cameras
Constant Charging Flash HP Photosmart R927 digital camera
First I'd try turning the flash off, a manual option on nearly all camera's. Take a couple of photo's without flash, and turn the camera off and on a couple of times then turn the flash back on to auto.
If that doesn't resolve the problem, I suggest going to the HP website, follow links to support and/or downloads and see if there's a firmware upgrade for your camera.
Apr 26, 2010 | HP Photosmart R927 Digital Camera
Does the R927 take panaramic pictures? If not, what cameras do you have that do?
The R927 does indeed have a panorama mode, which lets you take two to five pictures and stitch them together using the supplied software. See page 18 of the manual for more.
Mar 04, 2010 | HP Photosmart R927 Digital Camera
My Photosmart R927 will not turn on. I installed
Assuming that the new battery was the correct type and that it was fresh/fully charged, your problem may be due to or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 12, 2009 | HP Photosmart R927 Digital Camera
Camera won't charge on dock
usually this happens to old cameras and other devices. is your camera old?
Aug 11, 2009 | HP Photosmart R927 Digital Camera
Using SD HC Memory Card with HP R927 camera
No. The R927 is limited to SD cards 2GB and smaller.
Aug 25, 2008 | HP Photosmart R927 Digital Camera
R927 will not power on.
i had this problem with this camera when i had it new i would put the camera on the dock to charge and then use it then finally it wouldnt work and i realised that the camera wasnt charging. i contacted hp who i found to not be very helpful, they eventually sent me out a new battery even tho i told them i felt it wasnt the battery, of course the same thing happened with the new battery. i called them again and said i felt that there may be a loose connection in the wire going from the transformer to the dock as by messing around with it had made the light come on but as soon as i let go it went off, they agreed to send a replacement. when the replacement arrived they sent the part of the cable that plugged into mains and as such was no use, they siad they would send the right one but as yet i have not received it. =S however, by moving the wire where it plugs into the dock i have manged to get the camera to charge, it may be worth messing with the wire to see if this is the case with urs and calling for a replacement. claire xx =D
Apr 03, 2008 | HP Photosmart R927 Digital Camera
R927 digital camera
Are you sure that the battery is holding a charge? If it is holding a charge check the contacts on the battery and inside the camera. you can clean both of them with a pencil eraser gently rub the eraser on the contacts and this will clean them. I hope this helps you out and fixes your problem.
Mar 21, 2008 | HP Photosmart R927 Digital Camera
HP R927 Camera
I had this problem with my camera after a year. Scratching the battery contact terminal inside the camera fixed it.
Aug 19, 2007 | HP Photosmart R927 Digital Camera
HP Photosmart 935 Digital Camera Logo
90 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
