At the end of each cycle the bottom of the dishwasher is still full of cloudy water and we have to empty it manually. We've pulled it apartas far as we dare but found no obvious blockage. Any idea's?
I would check the bottom of the dishwasher to see if there are any bones, old food built up as some of these collection systems have a small disposer built into them. If you find any food, it's probably that. Also, you can make sure that the drain line is the proper length and high enough as this is a common problem. Do a good search on proper drain height for dishwasher. You may run an empty load of dishes with a cup of bleach added to eliminate the odor as well. Bleach will kill any bacteria causing the smell. More than likely the drain hose wasn't installed correctly.
These mechanical timer machines have to follow a series of logical steps to complete the program - ie, empty. fill to level 1. wash. heat to temp. etc etc
My guess is the machine is not heating, as you say it works for part of the program - or possibly it is not emptying correctly? check water heating element and drain pump.
Program 4 eco is a separate program from 3, using low temperature washing - the machine does stop between 3 and 4 normally and doesnt carry on through.
Check this link. Multiple causes are possible yet most is how drain is hooked up to disposal and back pressure built up. Hose must be installed correctly.
some dishwashers have water left after the final rinse. it is important to keep the motor seals wet between loads. My filter is always immersed. If we go away for two weeks, I put 2 litres of water into the tub and let it soak 24 hr so that I never start it with dry seals.
After cleaning the air gap thingy my machine works fine again. This thing sits on the left lower back side of the machine (left when you are standing in front of the machine). It is a transparent plastic box with 3 hoses attached (drain hose from pump, drain hose to the outside and water). Inside the box is a black plastic float. If debris gets caught in there the float gets stuck. Solution is to remove the part by pulling the 2 drain hoses out (there is a small black clip holding them in) and unclamp and remove the water hose. Rinse and shake the housing until the float moves freely again and reassemble.
Have tried drain clearers, taken apart as much as I can. still blocked
