Question about Sony Cameras
Hello , i have Sony Nex-Vg 20 Camera. I got error E:62:30. All i have is black screen when i turn it on. When i turn on camera i can hear that shutter doesn't open , it tries to open it but it can't.
I have tried everything , removing batteries , new batteries. Factory restart. Tapping on Lens. Cleaning Lens conectors and so on. I can't find error in internet. E:62:30.
SOURCE:
  • 67 Answers
SOURCE: HELP! dropped camera, lens won't go back in, shutter won't close
Tapp the lense GENTLY in the opposite direction of the misalignment
Posted on Dec 10, 2007
SOURCE: Nikon E5700 digital camara.
There is a service advisory out for Nikon E5700.
t has come to our attention that in a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras, an electronic component may, in some instances, fail affecting your camera's performance and/or operability.
While only a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras are affected by this advisory, if your camera presents symptoms that can include (1) images with a strong color tint, (2) images that are totally black and/or (3) images with visible defects, Nikon will, upon confirmation that the problem is associated to this Service Advisory, service your camera free of charge.
link to info is here: http://www.nikonusa.com/Service-And-Support/Service-Advisories/index.page
Posted on Jun 03, 2008
SOURCE: "Lens error - restart camera" message, but won't restart
I just had the same issue when one of my children drop the camera. I'm not wanting to break anyone's camera but I was able to open the lens cover and pull the lens out and then turning it on it retracted and worked just like it should.
Posted on Apr 20, 2009
SOURCE: lens error
if the problem is due to the fact that u have dropped the camera on floor or put into water...then no other go you should change the whole lens array...contact your nearest service centre
Posted on May 13, 2009
ginko
  • 19396 Answers
SOURCE: Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Posted on Jul 05, 2009
My Sony NEX-3n has a weak magnet that prevents the camera from taking more than one picture at a time,this makes the camera error turn power off then on
You will need to return the camera to Sony for service, they do not sell any parts or repair information to the public. The cost is about $200.00 US
Aug 18, 2016 | Sony Cameras
Bought this used. All the images appear to be low contrast and washed out. I've tried adjusting iso/exposure/shutter/aperture/etc.
Seee other response, I think that unles a change of lens brings a different result could well be a hardware fault
Jun 25, 2015 | Sony Alpha NEX-5R Mirrorless Digital...
The ringflash won't fire on this camera.
If the menu item is gray it means that you are in a mode that does not allow you control of your flash. You are likely in an auto mode. Change the mode to Manual, Shutter priority, Aperture priority, or Program.
Diane
NYC Photo Safari
Mar 12, 2014 | Bower SFD14S Sony Ringlight Flash
First a black screen, then a lens error
For the lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
No image on Cybershot DSC-T1
It is known problem of bad ccd imager in Sony DSC-T1 Cyebershot camera and ccd imager will be replaced.
Sony will repair this camera free of cost for ccd imager problem as per announced scheme. You will be charged $20 for shipment.
Click Sony CCD Imager Support fro details.
Apr 12, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Lumix dmc lx2
Does the menu show up on the screen, or is it totally black?
Does the camera take pictures and behaves as normal (apart from black screen ;)?
If the menu shows up then I'm afraid it's most probably something serious- like dead CCD or failed shutter (probably the latter-LX2s are not famous for failing CCDs). Failed shutter is easy to identify. You would normally hear a faint mechanical"click" when taking a picture (make sure you disable sounds in your camera). If you can't hear anything then the shutter might be dead. In cases like this I normally suggest getting a donor camera from ebay and replacing the lens (the shutter assembly is inside the lens but it's much easier to replace the whole lens).
Good luck,
Raf
Aug 04, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Cameras Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
