Question about Acer Aspire 3003LCi Notebook
Nothing but a fan and a flashing light
Thats all i get aparently someone upgraded the memory and this happened is there a fix ie bios muckup
  • 98 Answers
Try going back to the previous memory configuration, see if the unit comes up normaly. if it does, there is something wrong with the new memory configuration (defective memory module, incompatable memory type, etc)
Posted on Nov 27, 2007
Hi, i have recently been given a mother board. (intel desktop board, d915gag, lga775), I have wired it up correctly. But when i switch the pc on, it just reads all attached hardware and does nothing,
A) Who are your reply comments to?
Post the user names they go by.
B) LEAVE BIOS ALONE!!
Diagnose FULLY before you attempt it.
Someone refers you to upgrade your BIOS program, right off the bat; suggest you S-T-O-P!.
1) You missed important parts of a diagnostic flowchart,
plus,
2) You make O-N-E mistake in upgrading BIOS, and you can use your motherboard for a Frisbee.
A note before I go on............
IF, the power goes out when upgrading,....THAT'S IT FOLKS!
IF, you did not save a copy of the original BIOS, when asked and when upgrading; and do not know how to flash BIOS from a floppy drive, toss your motherboard in the trash.
IF, you did not save a copy of the original BIOS, when asked; and the BIOS upgrade you use is INCOMPATIBLE; toss the motherboard in the trash.
(Unless you know how to flash from a floppy drive)
What?
Yes. After the motherboard is put on the market, the BIOS program
will have an upgrade; about two weeks later.
Logic would dictate upgrading BIOS, then.
However if the BIOS program is working OK, Leave it alone.
Follows the old adage, "If it ain't broke, don't fix it."
The internet is filled with statements, that someone attempted upgrading their BIOS program; only to turn their motherboard into an expensive paperweight.
Moving on................
C) Why do you hope the OnBoard (Integrated) graphics are not turned off?
Just go into BIOS Setup, and ENABLE it.
D) A Monitor is NOT a plug and play item.
DO NOT plug in, or unplug when the computer is on.
E) With JUST the Processor, Ram Memory, and processor fan plugged into power; you should be able to bring the BIOS Setup screen, up.
That means;
1) The Harddrive data cable to motherboard is Unplugged from motherboard.
So is the power cable to it.
2) The optical drive (CD/DVD drive) data cable, is unplugged FROM motherboard.
3) NO card reader cables hooked to motherboard.
4) No Front Panel USB cables, hooked to motherboard.
(The front of your computer is the Front Panel)
5) Computer case fans are unplugged.
NOTHING!
Except Processor, processor fan wires hooked to motherboard, and Ram Memory.
(As soon as BIOS Setup is pulled up, use the ESC key.
The computer will now restart. Press the Power On button in, and hold it in. This will turn the computer off.
You don't want to linger in BIOS Setup too long, without having the computer case fans hooked up.
Don't want to overheat the Northbridge chip.
This is just a fast test )
F) Could be someone you received the motherboard from, did NOT know about Anti-Static Procedures.
Or perhaps yourself.
Didn't FOLLOW them?
Use the motherboard for a conversation piece.
(Or Frisbee, or toss in the trash)
G) The FIRST thing to check when dealing with a desktop computer, that isn't working; is to check the Power Supply.
Have to know the computer is getting power, AND the correct voltages; BEFORE going on.
(Besides the obvious, to see if the computer is dirty inside)
Otherwise it would be akin to trying to start a car, and finding out the battery is no good.
A Power Supply with a weak voltage power rail, will have enough power to light those simpy LED's, and maybe spins fans.
Will NOT however, have enough power to turn the PROCESSOR on.
Lot's of motherboards are tossed in the trash, because the user did not diagnose correctly, and Assumed the problem was the motherboard.
1) If ALL the LED's were lit up at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it is.
There are 3 main power rails;
A) 3.3 Volts
B) 5 Volts
C) 12 Volts
ALL are DC Voltage
ALL Black wires are Ground ( - ) wires.
[ In comparison two D cell flashlight batteries produce 3 Volts DC.
The dangerous high AC voltage from your home, or business; (100 to 240 volts, depending on country), is converted into the 3 low DC Voltages stated above.
The dangerous AC voltage is contained; WITHIN the metal case of the Power Supply ]
Use a multimeter set to DC Voltage. An economical model cost averages about $5 to $12.
Auto parts stores carry them. (More expensive though, usually)
I have seen them on checkout aisle racks, in major discount stores.
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
http://www.playtool.com/pages/psuconnectors/connectors.html
You are dealing with a DC circuit.
There is a Positive, and a Negative.
Negative is Ground.
Positive wires are the 3 main voltage power rails, stated above.
ALL Black wires are Ground wires.
To expound further;
ALL Orange wires are 3.3 Volts
ALL Red wires are 5 Volts
ALL Yellow wires are 12 Volts.
Positive (Red) probe lead of multimeter, goes TO power wire.
(3.3 Volts, or 5 Volts, or 12 Volts)
Negative (Black) wire goes to ANY Black wire.
Need guidance in testing the 3 main voltage power rails, post back in a Comment.
OR,
Use a KNOWN to be good, Compatible power supply; for a test unit.
Yes.
That means you can borrow one from a WORKING computer, IF it is compatible; for a temporary test unit.
Find the Power Supply is the problem? Replace.
Then reinstall the test Power Supply back into it's working computer.
Voltage power rails check to be good?
Then Processor, processor fan, and Ram Memory.
See if you can bring BIOS Setup, up.
If no, the motherboard is bad.
Probably Static shocked, somewhere along the way.
BIOS Setup comes up?
Then reinstall harddrive. Check again.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 20, 2013 | Intel D915GAG Socket 775 Motherboard -...
Upgrade the bios from windows 7
You never flash a BIOS within Windows. That's like running across a busy freeway. There is a chance you might not make it. And, you only flash the BIOS if you truly have a severe problem. You don't.
4GB is unobtainable within a 32bit system. The most Windows will end up utilizing is in the low 3GB's. This has been around for ages, and someone should have fixed it by now.
Ending up with a dead CMOS chip is as bad as it gets. In the end it is up to you whether to flash or not. All I could do was give you some advice.
http://www.techrepublic.com/blog/10things/10-common-mistakes-you-should-avoid-when-flashing-your-bios/357
Oct 06, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Model Asus Eee 900A I tried to update bios and all of a sudden everything went off now no power at all, buttery is in good condition power charger is in good condition tried them on an other Eee and found...
I'm sorry but looks like the BIOS maybe damaged - you'll have to get the BIOS fixed or replaced (on the motherboard) unless it has a socket. If anything happened during the upgrade process like a power interruption, it could cause the problem. The BIOS upgrade process does an erase/write flash of firmware to its' memory. If disrupted, the firmware codes become corrupted.
Oct 29, 2010 | ASUS Eee PC 900 Notebook
Dell d600 latitude laptop not booting after using and installing vista upgrade disk. Vista o/s installed just fine, it did all the required shut downs and reboots required during the install ok and was...
the bios for the computer might not be capatibe with the os upgrade if the hard drive is removed from the laptop it might boot or the bios will have to be cleared and flashed with a new one
Nov 17, 2009 | Cars & Trucks
Upgrading ram
You can only run 2gig max IE: 2- 1gig or 1-2gig you cant run 2-2gig the bios will not accept it
Mar 13, 2009 | Toshiba Satellite P205-S6337 Notebook
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Acer 3680-2633 won't boot with new ram install
Dont be hasty! First of all, not all ram and motherboard are created alike.
1. go to the specifications of the RAM and find out what voltage its expecting from the motherboard. this may require just looking at your receipt or going the the manufacturers website and looking at the specs or calling them.
2. check your motherboard manual or access it from the manufacturers site and check the highest voltage that it will supply to the RAM.
if the RAM Needs more voltage than your motherboard supplies, it will cause the symptoms your describing. In this case you will need to find some PC4200 ram that runs at your motherboards voltage.
I have ordered many barebone computers that were shipped with upgraded memory that wouldnt work on that system, the sales people are more interested in selling than checking the specs.
Oct 06, 2008 | Acer Aspire 3680 Laptop
P5NT won't boot
I went throught this and it is really silly. The P5N-T motherboard has a problem with some of the new energy efficient CPUs. The fix was to insert an older CPU and upgrade the bios and then it would recognize the new CPU. If you happen not to have an older 775 CPU laying around (most people do not), it might be easiest to return it and get a different board - or maybe the store can upgrade the bios for you.
Oct 05, 2008 | Computers & Internet
Acer Aspire 3003LCi Notebook Logo
35 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
